Valentina Cereseto
Valentina Cereseto answered on May 16, 2016 6:13 PM
Thanks a lot Mike. Your reply clarified me a lot!
Bye
Valentina
Valentina Cereseto
Valentina Cereseto answered on May 10, 2016 7:36 PM
Hi Mike,
thanks for your explanation.
Yes, this could be a difficult task.
Since I am in the middle of a new UI layout of legacy application and we want to apply localization everywhere, an adaptive layout is kind of a requisite. Apart from UltraTabControl, are there other Infragistics "Container" controls that do not support auto sizing features? So far, I only got stuck with UltraTabControl and OptionSet. I need as much flexibility I can get
Thanks a lot again
Valentina
Valentina Cereseto
Valentina Cereseto answered on May 10, 2016 3:00 AM
Hi Mike,
thanks for your feedback.
Yes you are right. I didn't make my issue clear. What I was thinking about is.. why the UltraTabControl does not provide AutoSize property?
With every control. if the space needed is bigger than control size, everything would grow accordingly. Here, it is not possible.
How could I achieve this, as you suggested, make the tab control larger?
Thanks again
Valentina
Valentina Cereseto
Valentina Cereseto answered on May 9, 2016 7:13 PM
Hi Sahaja,
actually it is not working good. Yes, as I stated too, the Tab Header resizes, according to tab header text length. Unfortunately, the form iteself maintains same size. Contents are moved according to their anchor properties, but.. my grey box is actually a panel containing labels and textboxes. If tab header text length is very long, this panel is literally cut, a portion of it goes out of visibility.
If text in Tab header gets wider, I see that UltraTabControl.TabPageSize gets smaller and smaller. I would like it to be adaptive!
Is there a way to force the tab page size..to be the right size to accommodate all its content, instead to be (Form.size – TabHeader. NEW size)?
Thanks a lot
valentina
