Infragistics Community Forum / Web / Ignite UI for React / React Data Grid npm – I Installed Ignite UI for React but Can’t Find the Grid
Alex A
Alex A asked on Mar 18, 2026 12:27 PM
I installed Ignite UI for React from npm, but I don’t see any grid components available. I expected to use a React Data Grid, but I can’t find it in the package I installed. Where can I find the React grid component in npm?
    Vasya Kacheshmarova
    Vasya Kacheshmarova answered on Mar 18, 2026 1:54 PM
    Hello Alex,
    All the React grid components are distributed in separate npm packages. If you installed the base Ignite UI package you won’t see the grids automatically.
    You can choose between two options: Open-source React Grid Lite or advanced React Grids with more features.
    Open-source React Grid Lite (MIT Licensed) – this is a lightweight React data grid that is fully open source and free for production use. https://www.npmjs.com/package/igniteui-react
    It’s in the igniteui-react package under the grid-lite entry point.
    React Grid Lite is ideal when you need a simple data grid with common functionality but without the full enterprise feature set. It’s a great option for lightweight data tables, basic dashboards, simple grid scenarios, projects that require MIT-licensed open-source components
    Here’s the official documentation
    https://www.infragistics.com/products/ignite-ui-react/react/components/grid-lite/overview
    If you need more advanced capabilities and enterprise features, go with the advanced React Grids (Data Grid, Tree Grid, Hierarchical Grid, Pivot Grid)
    You should install the igniteui-react-grids npm package https://www.npmjs.com/package/igniteui-react-grids
    These grids provide enterprise-grade functionality including:
    • virtualization for large datasets
    • advanced filtering and sorting
    • hierarchical data support
    • pivot tables
    • complex data editing scenarios
    You can check out the documentation here
    https://www.infragistics.com/products/ignite-ui-react/react/components/grids/data-grid
    For any additional questions about installing or using the React grids, feel free to write back.
    Vasya kacheshmarova
    Software Developer
    Alex A
    Alex A answered on Mar 18, 2026 2:43 PM
    Thank you 🙂
    Vasya Kacheshmarova
    Vasya Kacheshmarova answered on Mar 18, 2026 2:46 PM
    Hi Alex,
    Do not hesitate to contact me if you have any additional questions.
    Vasya kacheshmarova
    Software Developer
    lily lily
    lily lily answered on Oct 16, 2026 4:10 AM
    I had the same question when looking for the React Data Grid in Ignite UI. It seems the grid component may be available through a separate npm package rather than the main package. It would be helpful if the documentation clearly explained which package to install and provided a simple example of importing and using the React Data Grid. This would make it much easier for developers to get started.  sunpass login
Alex A
1 week, 3 days ago
