Infragistics Community Forum / Cross Platform / Ultimate UI for Xamarin / vb6 with Sheridan ssOleDBGrid shows no data on Win7
Josef
Josef asked on Jun 5, 2014 4:15 PM
My VB6 application
uses theSheridan ssOleDBGrid to display table data from a MS SQL Server
data base. The data grid is bound via a MS ADO Data Control named
“adoDC”. The connection occurs thru the DataEnvironment “deAlpha” via
connection “Alpha” (an ODBC connection).
Test example:
Private Sub Form_Load()
Dim sql As String
Dim sConnect As String
deAlpha.Alpha.Open
sConnect = deAlpha.Alpha.ConnectionString
sql = “Select * from Alpha”
With adoDc
.ConnectionString = sConnect
.RecordSource = sql
.Refresh
MsgBox .Recordset.RecordCount
End With ‘adoDC
ssgTest.Caption = “Rows: ” & Format$(ssgTest.Rows, “0”)
End Sub
On WinXP the message box reads”50782″. The Grid displays data as expected and the caption is “Rows: 50782”.
On Win7 the message box reads “50782”. The Grid displays nothing and the caption is “Rows: 0”.
So it seems that no data at all are connected to the grid.
As far as I know all needed dll’s and ocx are placed into the directory where the exe file is residing.
What may be going wrong?
Note:
If I use Unbound Mode even under Win7 runs well. But that would mean havy recoding of a large project!
    Danko Valkov
    Danko Valkov answered on Mar 23, 2012 3:43 PM
    Hello jschramm,
    I have been looking into this forum thread, and what I could suggest here is taking a look at the following link from our web site, describing what are the currently supported environments for each platform:
    http://www.infragistics.com/support/supported-environments.aspx#SupportedEnvironments
    Please feel free to let us know if you have any other questions.
      Ed
      Ed answered on Mar 27, 2012 2:59 AM
      There are still many users out in the world thatrely on DataWidgets. I have a similar problem on windows 7 ultimate. Add-item widgets work fine but bound ones do not.  Yet on a Windows 7 home premium PC everything works. Please tell us which  file is needed for bound data objects so we can continue using this asset.
      Josef
      Josef answered on Mar 27, 2012 8:10 AM
      Hello Danko Valkov,
      I allready did know that Infragistics does not support Sheridan products – therefore I addressed this forum asking for help.
      Nevertheless thanks
      jschramm
    Ed
    Ed answered on Mar 27, 2012 3:00 AM
    Did you ever find a solution?
    The bound data objects will work on win 7 home premium
      Josef
      Josef answered on Mar 27, 2012 8:20 AM
      “Did you ever find a solution?”
      No, I found nothing at all.
      “The bound data objects will work on win 7 home premium”
      But this fact is new for me. I will do some more investigation
      jschramm
        Ed
        Ed answered on Mar 28, 2012 4:09 AM
        I have it running in a program on a win 7 ultimate laptop in bound mode. But not running in bound mode on a win 7 ultimre desktop in the same program.
        There has to be a missing registry entry.
        Danko Valkov
        Danko Valkov answered on Mar 28, 2012 7:44 AM
        Hello Edmac,
        If you believe that this might be connected with the registry entries in your machine, you could take a look at the following forum thread where the registry keys created after an installation are mentioned:
        http://community.infragistics.com/forums/p/52530/340148.aspx#340148
        If you have any other questions please feel free to let us know.
        Ed
        Ed answered on Apr 12, 2012 12:02 AM
        Just reinstalled a clean edition of win 7 Ultimate on a Dell laptop.  After all windows updates and Office 10 were installed,I lowered the UAC to the minimum, then  I installed my VB 6 program that uses Sheridan Data Widgets. I ran the vb6 install program as Administor.
        All Sheridan controls are working in the vb 6 program!!!!
        Ed
        Alan Halama
        Alan Halama answered on Apr 12, 2012 12:50 PM
        edmac,
        Thank you for providing the update on how you got the controls to work on Windows 7 Ultimate.
        bonie kay
        bonie kay answered on Jun 3, 2014 2:29 PM
        Hi there
        I too am experiencing a problem installing Designer Widgets on win 7 64bit. My problematic control is ssdock32.ocx. I need some clarity on installing designer widgets on a 64 bit platform and if there is any workaround. i hope you will be able to help
        Alan Halama
        Alan Halama answered on Jun 5, 2014 3:22 PM
        Bonnie,
        Does the approach posted here work for you?
        bonie kay
        bonie kay answered on Jun 5, 2014 3:30 PM
        oh ya it worked after manipulating the registry then copying the controls folder to program files(x86) and registering the controls…now am fighting with these TDBInput 5.0 controls again
        Alan Halama
        Alan Halama answered on Jun 5, 2014 4:15 PM
        Bonnie,
        Thank you for letting me know it is working.  I believe that the TDB Input controls were provided by Component One so if you need assistance with those, it would be best to look at their forums.
Josef
12 years, 5 months ago
Jun 5, 2014 4:15 PM
Feb 23, 2026 3:51 PM
