Infragistics Community Forum / General / BC30560: 'WebScriptManager' is ambiguous in the namespace 'Infragistics.Web.UI'.
New DiscussionI’m using 2012.2 on ASP.NET v4.5 on a Win2k8 R2 box. I used to use 2012.1. I have run the Version Utility on my project and the site. However, I’m still getting this.
I have uninstalled 2012.1 and reinstalled 2012.2 with no improvement.
Is there any other information you need to help me determine the problem. I’m a long-time programmer but I’m a newb to object oriented and .NET.
I am just another user, so my answer isn't authoritative
Three things I would check…
1) Check that you don't have the version 12.1 dll's in the bin folder
2) Check that you don't have references to both assembly versions in your web.config file
3) Check that you don't have a reference to the 12.1 assembly at the top of your page
1. The only Infragistics DLL in my or the server's bin is the 12.2 version.
2. Here's the web.config section with the references:
<assemblies>
<add assembly="System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=B77A5C561934E089"/>
<add assembly="System.Design, Version=4.0.0.0, Culture=neutral, PublicKeyToken=B03F5F7F11D50A3A"/>
<add assembly="Infragistics4.Web.v12.2, Version=12.2.20122.1007, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb"/>
<add assembly="Infragistics4.WebUI.Documents.Reports.v12.2, Version=12.2.20122.1007, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb"/>
<add assembly="Infragistics4.WebUI.Documents.Excel.v12.2, Version=12.2.20122.1007, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb"/>
<add assembly="Infragistics4.WebUI.Documents.Word.v12.2, Version=12.2.20122.1007, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb"/>
<add assembly="Infragistics4.WebUI.Documents.IO.v12.2, Version=12.2.20122.1007, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb"/>
<add assembly="Infragistics4.WebUI.Documents.Core.v12.2, Version=12.2.20122.1007, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb"/>
<add assembly="Infragistics45.Web.v12.2, Version=12.2.20122.1007, Culture=neutral, PublicKeyToken=7DD5C3163F2CD0CB"/>
<add assembly="Infragistics45.WebUI.Documents.Reports.v12.2, Version=12.2.20122.1007, Culture=neutral, PublicKeyToken=7DD5C3163F2CD0CB"/>
<add assembly="Infragistics45.WebUI.Documents.Excel.v12.2, Version=12.2.20122.1007, Culture=neutral, PublicKeyToken=7DD5C3163F2CD0CB"/>
<add assembly="Infragistics45.WebUI.Documents.Word.v12.2, Version=12.2.20122.1007, Culture=neutral, PublicKeyToken=7DD5C3163F2CD0CB"/>
<add assembly="Infragistics45.WebUI.Documents.IO.v12.2, Version=12.2.20122.1007, Culture=neutral, PublicKeyToken=7DD5C3163F2CD0CB"/>
</assemblies>
</compilation>3. Here's what is at the top of my Site.Master page:
<%@ Register Assembly="Infragistics4.Web.v12.2, Version=12.2.20122.1007, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" Namespace="Infragistics.Web.UI.ListControls" TagPrefix="ig" %>
<%@ Register Assembly="Infragistics4.Web.v12.2, Version=12.2.20122.1007, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" Namespace="Infragistics.Web.UI.LayoutControls" TagPrefix="ig" %>
The detailed compile looks like this:
c:\windows\system32\inetsrv> "C:\Windows\Microsoft.NET\Framework64\v4.0.30319\vbc.exe" /t:library /utf8output /R:"C:\Windows\Microsoft.Net\assembly\GAC_MSIL\System.Configuration\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.Configuration.dll" /R:"C:\Windows\Microsoft.Net\assembly\GAC_MSIL\System\v4.0_4.0.0.0__b77a5c561934e089\System.dll" /R:"C:\Windows\Microsoft.NET\Framework64\v4.0.30319\Temporary ASP.NET Files\root\e22c2559\92c7e946\assembly\dl3\14e3493f\00987ead_e586cd01\DotNetOpenAuth.OAuth.Consumer.dll" /R:"C:\Windows\Microsoft.Net\assembly\GAC_MSIL\Microsoft.CSharp\v4.0_4.0.0.0__b03f5f7f11d50a3a\Microsoft.CSharp.dll" /R:"C:\Windows\Microsoft.NET\Framework64\v4.0.30319\Temporary ASP.NET Files\root\e22c2559\92c7e946\assembly\dl3\a32a663d\8020f0a6_e586cd01\Microsoft.ScriptManager.MSAjax.dll" /R:"C:\Windows\Microsoft.Net\assembly\GAC_MSIL\System.Xml\v4.0_4.0.0.0__b77a5c561934e089\System.Xml.dll" /R:"C:\Windows\Microsoft.NET\Framework64\v4.0.30319\Temporary ASP.NET Files\root\e22c2559\92c7e946\assembly\dl3\13d8778c\80f3bea5_e586cd01\System.Web.Providers.dll" /R:"C:\Windows\Microsoft.Net\assembly\GAC_64\System.EnterpriseServices\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.EnterpriseServices.dll" /R:"C:\Windows\Microsoft.Net\assembly\GAC_MSIL\Infragistics4.WebUI.Documents.Reports.v12.2\v4.0_12.2.20122.1007__7dd5c3163f2cd0cb\Infragistics4.WebUI.Documents.Reports.v12.2.dll" /R:"C:\Windows\Microsoft.Net\assembly\GAC_MSIL\Infragistics45.Web.v12.2\v4.0_12.2.20122.1007__7dd5c3163f2cd0cb\Infragistics45.Web.v12.2.dll" /R:"C:\Windows\Microsoft.Net\assembly\GAC_MSIL\System.Data.DataSetExtensions\v4.0_4.0.0.0__b77a5c561934e089\System.Data.DataSetExtensions.dll" /R:"C:\Windows\Microsoft.NET\Framework64\v4.0.30319\Temporary ASP.NET Files\root\e22c2559\92c7e946\assembly\dl3\5e7c0e06\008a57a6_e586cd01\System.Web.Optimization.dll" /R:"C:\Windows\Microsoft.Net\assembly\GAC_MSIL\System.ComponentModel.DataAnnotations\v4.0_4.0.0.0__31bf3856ad364e35\System.ComponentModel.DataAnnotations.dll" /R:"C:\Windows\Microsoft.Net\assembly\GAC_64\System.Data\v4.0_4.0.0.0__b77a5c561934e089\System.Data.dll" /R:"C:\Windows\Microsoft.Net\assembly\GAC_MSIL\Infragistics45.WebUI.Documents.Excel.v12.2\v4.0_12.2.20122.1007__7dd5c3163f2cd0cb\Infragistics45.WebUI.Documents.Excel.v12.2.dll" /R:"C:\Windows\Microsoft.Net\assembly\GAC_MSIL\System.WorkflowServices\v4.0_4.0.0.0__31bf3856ad364e35\System.WorkflowServices.dll" /R:"C:\Windows\Microsoft.Net\assembly\GAC_MSIL\Infragistics45.WebUI.Documents.Word.v12.2\v4.0_12.2.20122.1007__7dd5c3163f2cd0cb\Infragistics45.WebUI.Documents.Word.v12.2.dll" /R:"C:\Windows\Microsoft.Net\assembly\GAC_MSIL\System.Web.Entity\v4.0_4.0.0.0__b77a5c561934e089\System.Web.Entity.dll" /R:"C:\Windows\Microsoft.Net\assembly\GAC_MSIL\Infragistics4.WebUI.Documents.Excel.v12.2\v4.0_12.2.20122.1007__7dd5c3163f2cd0cb\Infragistics4.WebUI.Documents.Excel.v12.2.dll" /R:"C:\Windows\Microsoft.Net\assembly\GAC_MSIL\System.Core\v4.0_4.0.0.0__b77a5c561934e089\System.Core.dll" /R:"C:\Windows\Microsoft.Net\assembly\GAC_MSIL\System.Web.DynamicData\v4.0_4.0.0.0__31bf3856ad364e35\System.Web.DynamicData.dll" /R:"C:\Windows\Microsoft.Net\assembly\GAC_64\System.Web\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.Web.dll" /R:"C:\Windows\Microsoft.Net\assembly\GAC_MSIL\System.Drawing\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.Drawing.dll" /R:"C:\Windows\Microsoft.NET\Framework64\v4.0.30319\Temporary ASP.NET Files\root\e22c2559\92c7e946\assembly\dl3\3f73673b\008a57a6_e586cd01\AspNet.ScriptManager.jQuery.UI.Combined.dll" /R:"C:\Windows\Microsoft.NET\Framework64\v4.0.30319\Temporary ASP.NET Files\root\e22c2559\92c7e946\assembly\dl3\f64c35d8\8001e6ac_e586cd01\DotNetOpenAuth.Core.dll" /R:"C:\Windows\Microsoft.NET\Framework64\v4.0.30319\Temporary ASP.NET Files\root\e22c2559\92c7e946\assembly\dl3\c9fbd719\80f3bea5_e586cd01\Antlr3.Runtime.dll" /R:"C:\Windows\Microsoft.Net\assembly\GAC_MSIL\System.ServiceModel.Activation\v4.0_4.0.0.0__31bf3856ad364e35\System.ServiceModel.Activation.dll" /R:"C:\Windows\Microsoft.Net\assembly\GAC_MSIL\System.ServiceModel.Activities\v4.0_4.0.0.0__31bf3856ad364e35\System.ServiceModel.Activities.dll" /R:"C:\Windows\Microsoft.NET\Framework64\v4.0.30319\Temporary ASP.NET Files\root\e22c2559\92c7e946\App_global.asax.8b2k–5e.dll" /R:"C:\Windows\Microsoft.NET\Framework64\v4.0.30319\Temporary ASP.NET Files\root\e22c2559\92c7e946\assembly\dl3\85a098b7\8020f0a6_e586cd01\Microsoft.ScriptManager.WebForms.dll" /R:"C:\Windows\Microsoft.Net\assembly\GAC_MSIL\System.IdentityModel\v4.0_4.0.0.0__b77a5c561934e089\System.IdentityModel.dll" /R:"C:\Windows\Microsoft.NET\Framework64\v4.0.30319\Temporary ASP.NET Files\root\e22c2559\92c7e946\assembly\dl3\a6e49b4b\00987ead_e586cd01\DotNetOpenAuth.AspNet.dll" /R:"C:\Windows\Microsoft.NET\Framework64\v4.0.30319\Temporary ASP.NET Files\root\e22c2559\92c7e946\assembly\dl3\6d95e1fd\8001e6ac_e586cd01\DotNetOpenAuth.OAuth.dll" /R:"C:\Windows\Microsoft.Net\assembly\GAC_MSIL\Infragistics4.WebUI.Documents.IO.v12.2\v4.0_12.2.20122.1007__7dd5c3163f2cd0cb\Infragistics4.WebUI.Documents.IO.v12.2.dll" /R:"C:\Windows\Microsoft.Net\assembly\GAC_MSIL\Infragistics45.WebUI.Documents.Reports.v12.2\v4.0_12.2.20122.1007__7dd5c3163f2cd0cb\Infragistics45.WebUI.Documents.Reports.v12.2.dll" /R:"C:\Windows\Microsoft.Net\assembly\GAC_MSIL\Infragistics4.WebUI.Documents.Core.v12.2\v4.0_12.2.20122.1007__7dd5c3163f2cd0cb\Infragistics4.WebUI.Documents.Core.v12.2.dll" /R:"C:\Windows\Microsoft.Net\assembly\GAC_MSIL\Infragistics4.WebUI.Documents.Word.v12.2\v4.0_12.2.20122.1007__7dd5c3163f2cd0cb\Infragistics4.WebUI.Documents.Word.v12.2.dll" /R:"C:\Windows\Microsoft.Net\assembly\GAC_MSIL\System.Activities\v4.0_4.0.0.0__31bf3856ad364e35\System.Activities.dll" /R:"C:\Windows\Microsoft.NET\Framework64\v4.0.30319\Temporary ASP.NET Files\root\e22c2559\92c7e946\assembly\dl3\d4178a80\00c5afae_e586cd01\Microsoft.AspNet.Membership.OpenAuth.dll" /R:"C:\Windows\Microsoft.Net\assembly\GAC_MSIL\System.Xml.Linq\v4.0_4.0.0.0__b77a5c561934e089\System.Xml.Linq.dll" /R:"C:\Windows\Microsoft.NET\Framework64\v4.0.30319\Temporary ASP.NET Files\root\e22c2559\92c7e946\assembly\dl3\b995934b\008a57a6_e586cd01\AspNet.ScriptManager.jQuery.dll" /R:"C:\Windows\Microsoft.Net\assembly\GAC_MSIL\System.Web.Services\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.Web.Services.dll" /R:"C:\Windows\Microsoft.Net\assembly\GAC_MSIL\System.Web.ApplicationServices\v4.0_4.0.0.0__31bf3856ad364e35\System.Web.ApplicationServices.dll" /R:"C:\Windows\Microsoft.NET\Framework64\v4.0.30319\Temporary ASP.NET Files\root\e22c2559\92c7e946\assembly\dl3\aa6b5db7\96c9c956_eebdcd01\ITS.dll" /R:"C:\Windows\Microsoft.Net\assembly\GAC_MSIL\System.Design\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.Design.dll" /R:"C:\Windows\Microsoft.Net\assembly\GAC_MSIL\System.Web.Extensions\v4.0_4.0.0.0__31bf3856ad364e35\System.Web.Extensions.dll" /R:"C:\Windows\Microsoft.Net\assembly\GAC_MSIL\Infragistics45.WebUI.Documents.IO.v12.2\v4.0_12.2.20122.1007__7dd5c3163f2cd0cb\Infragistics45.WebUI.Documents.IO.v12.2.dll" /R:"C:\Windows\Microsoft.NET\Framework64\v4.0.30319\Temporary ASP.NET Files\root\e22c2559\92c7e946\assembly\dl3\505ef7dd\00987ead_e586cd01\DotNetOpenAuth.OpenId.RelyingParty.dll" /R:"C:\Windows\Microsoft.NET\Framework64\v4.0.30319\Temporary ASP.NET Files\root\e22c2559\92c7e946\assembly\dl3\bace8d7c\00987ead_e586cd01\DotNetOpenAuth.OpenId.dll" /R:"C:\Windows\Microsoft.Net\assembly\GAC_MSIL\System.ServiceModel\v4.0_4.0.0.0__b77a5c561934e089\System.ServiceModel.dll" /R:"C:\Windows\Microsoft.Net\assembly\GAC_MSIL\System.Runtime.Serialization\v4.0_4.0.0.0__b77a5c561934e089\System.Runtime.Serialization.dll" /R:"C:\Windows\Microsoft.Net\assembly\GAC_MSIL\Infragistics4.Web.v12.2\v4.0_12.2.20122.1007__7dd5c3163f2cd0cb\Infragistics4.Web.v12.2.dll" /R:"C:\Windows\Microsoft.Net\assembly\GAC_MSIL\System.ServiceModel.Web\v4.0_4.0.0.0__31bf3856ad364e35\System.ServiceModel.Web.dll" /R:"C:\Windows\Microsoft.Net\assembly\GAC_MSIL\System.Windows.Forms\v4.0_4.0.0.0__b77a5c561934e089\System.Windows.Forms.dll" /R:"C:\Windows\Microsoft.NET\Framework64\v4.0.30319\Temporary ASP.NET Files\root\e22c2559\92c7e946\assembly\dl3\96408140\80f3bea5_e586cd01\WebGrease.dll" /R:"C:\Windows\Microsoft.NET\Framework64\v4.0.30319\Temporary ASP.NET Files\root\e22c2559\92c7e946\assembly\dl3\6654c881\00b788a7_e586cd01\Microsoft.Web.Infrastructure.dll" /R:"C:\Windows\Microsoft.NET\Framework64\v4.0.30319\Temporary ASP.NET Files\root\e22c2559\92c7e946\assembly\dl3\b0b05ffa\802e17ae_e586cd01\EntityFramework.dll" /R:"C:\Windows\Microsoft.NET\Framework64\v4.0.30319\Temporary ASP.NET Files\root\e22c2559\92c7e946\assembly\dl3\fbcda224\00e95f97_9c7ccd01\Microsoft.AspNet.Web.Optimization.WebForms.dll" /out:"C:\Windows\Microsoft.NET\Framework64\v4.0.30319\Temporary ASP.NET Files\root\e22c2559\92c7e946\App_Web_nwxuitma.dll" /D:DEBUG=1 /debug+ /win32resource:"C:\Windows\Microsoft.NET\Framework64\v4.0.30319\Temporary ASP.NET Files\root\e22c2559\92c7e946\nwxuitma.res" /nowarn:41008,40000,40008 /define:_MYTYPE=\"Web\" /imports:Microsoft.VisualBasic,System,System.Collections,System.Collections.Generic,System.Collections.Specialized,System.ComponentModel.DataAnnotations,System.Configuration,System.Linq,System.Text,System.Text.RegularExpressions,System.Web,System.Web.Caching,System.Web.DynamicData,System.Web.SessionState,System.Web.Security,System.Web.Profile,System.Web.UI,System.Web.UI.WebControls,System.Web.UI.WebControls.WebParts,System.Web.UI.HtmlControls,System.Xml.Linq,System.Web.Optimization /warnaserror- /optionInfer+ "C:\Windows\Microsoft.NET\Framework64\v4.0.30319\Temporary ASP.NET Files\root\e22c2559\92c7e946\App_Web_nwxuitma.0.vb" "C:\Windows\Microsoft.NET\Framework64\v4.0.30319\Temporary ASP.NET Files\root\e22c2559\92c7e946\App_Web_nwxuitma.1.vb"
Microsoft (R) Visual Basic Compiler version 11.0.50709.17929
Copyright (c) Microsoft Corporation. All rights reserved.C:\Windows\Microsoft.NET\Framework64\v4.0.30319\Temporary ASP.NET Files\root\e22c2559\92c7e946\App_Web_nwxuitma.0.vb(787) : error BC30560: 'WebScriptManager' is ambiguous in the namespace 'Infragistics.Web.UI'.
Private Function __BuildControlWebScriptManager1() As Global.Infragistics.Web.UI.WebScriptManager
C:\Windows\Microsoft.NET\Framework64\v4.0.30319\Temporary ASP.NET Files\root\e22c2559\92c7e946\App_Web_nwxuitma.0.vb(788) : error BC30560: 'WebScriptManager' is ambiguous in the namespace 'Infragistics.Web.UI'.Dim __ctrl As Global.Infragistics.Web.UI.WebScriptManager
C:\Windows\Microsoft.NET\Framework64\v4.0.30319\Temporary ASP.NET Files\root\e22c2559\92c7e946\App_Web_nwxuitma.0.vb(1265) : error BC30560: 'WebScriptManager' is ambiguous in the namespace 'Infragistics.Web.UI'.Dim __ctrl2 As Global.Infragistics.Web.UI.WebScriptManager
C:\inetpub\wwwroot\Site.Master(26) : error BC30560: 'WebScriptManager' is ambiguous in the namespace 'Infragistics.Web.UI'.__ctrl = New Global.Infragistics.Web.UI.WebScriptManager()
Hello Mcase,
Looking at the list of referenced assemblies from your web.config, it seems that both 4and 4.5Infragistics assemblies are being referenced, for instance:
All assembly references including in the web.config and in the page/master page directives should point to one CLR version of the assemblies.
Please let me know if this helps.
When I saw your reply, I thought for sure that would do it. It didn't. Here's the web.config now:
<compilation strict="false" explicit="true" targetFramework="4.5" debug="true">
<assemblies>
</assemblies>
</compilation>I checked the file on the development server and it's identical. I also rebooted the development server (different reason) so IIS is reset.
Any other thoughts?
Hello mcase,
Thank you for your reply.
Can you confirm that the Master page directives also point to the 4.5 assemblies ?
"3. Here's what is at the top of my Site.Master page:
<%@ Register Assembly="Infragistics4.Web.v12.2, Version=12.2.20122.1007, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" Namespace="Infragistics.Web.UI.LayoutControls" TagPrefix="ig" %>"
its type (Infragistics.Web.UI.GridControls.WebDataGrid) is not compatible with the type of control (Infragistics.Web.UI.GridControls.WebDataGrid)
I got this error with the following control in asp.net 4.0. Any idea how to fix it? Thanks. The b…
+ 2
General
How to use Infragistics CSS in new ASP.NET Web Forms app
I created a new ASP.NET Web Forms app and placed an Infragistics web control onto the Site.Master p…Infragistics Web Data Grid – Requests Blocked by WAF(Imperva Secure Sphere)
Hello, We are facing the below issues and so the requests are blocked by Web Application Firewall(I…System.NullReferenceException: Object reference not set to an instance of an object. at Infragistics.Web.UI.DataSourceControls.WebHierarchicalDataSource.FindControlRecursive(Control root, String id)
I have an unbound checkbox, template field (with button) and a couple of bound fields. The grid has…Tags
Nov 13, 2012 4:14 PM
Feb 25, 2026 9:44 AM
