Andrew Goldenbaum
Andrew Goldenbaum answered on Oct 16, 2026 3:28 PM
Hello Tobias,
Did you set the PreserveMembersOrder property on the FlatDataSource to false? If not, the rows and columns will ignore the sort and show up in the order of the items within the FlatDataSource.ItemsSource that you assign.
If you have not tried this, please do so, and let me know if the sort is working.
Andrew Goldenbaum
Andrew Goldenbaum answered on Oct 15, 2026 3:34 PM
Hello Tobias,
In order to sort the rows and columns of the XamPivotGrid, I would recommend taking a look at the following documentation: https://www.infragistics.com/help/wpf/xampivotgrid-sorting-rows-and-columns.
The above topic goes over how to define HierarchyDescriptors for your FlatDataSource in order to sort the different hierarchies in the grid. Additionally, if you are looking to be able to simply sort the data/measures of the grid at runtime, I would recommend checking out this topic as well: https://www.infragistics.com/help/wpf/xampivotgrid-us-sorting-data.
Andrew Goldenbaum
Software Developer
Andrew Goldenbaum
Andrew Goldenbaum answered on Oct 6, 2026 2:40 PM
Hello Jakub,
I have been investigating the behavior you are reporting, and unfortunately the best thing I can recommend at this time is essentially what you are currently doing.
Since the Trigger for the Opacity control is within the ControlTemplate.Triggers, this unfortunately makes it necessary that the entire ControlTemplate is kept local as if you were to write a Style based on the RoyalLight DataRecordPresenter style and add a Trigger to the Style.Triggers collection, it would essentially just stack with the existing Trigger in the ControlTemplate.Triggers collection. Also, since WPF only keeps a single local style per control, there is no way to essentially “only” target a single Trigger.
At this time, there is no theming resource to control this, but I feel that there should be and it would not be a difficult thing to create. As such, I am going to log a feature request / development item for this so that one is potentially developed in a future version of the Infragistics for WPF toolset so that this should be as simple as a single line of code via a Style resource.
Andrew Goldenbaum
Software Developer – Team Lead
Andrew Goldenbaum
Andrew Goldenbaum answered on Aug 17, 2026 3:08 PM
Hello Quid,
Thank you for contacting Infragistics Developer Support.
I have been investigating into the behavior you are seeing, and I have a few questions for you on this matter, as I have not yet been able to reproduce this issue. Can you please provide an answer to the following?
  1. What version of .NET Framework / .NET Core are you targeting in your application?
  2. It looks like the exception is coming from an UltraPanel. Do you have more details on how you are using the UltraPanel in your application?
Andrew Goldenbaum
Andrew Goldenbaum answered on Apr 23, 2026 2:35 PM
Hello Darin,
While I do not have a runnable example of this at the moment, I do have some guidance on how one could create this. My best recommendation would be to utilize the UltraGeographicMap with a GeographicShapeSeries. You can find documentation on how to use this series type here: https://www.infragistics.com/help/winforms/geographicmap-using-geographic-shape-series. Note, you would need to find a shape file that has each of the states of the US as a separate shape.
The GeographicShapeSeries has an event named AssigningShapeStyle that you could utilize that will give you information about each shape in the shape file, and if you have information about the sales of each of the states in this case, you can then set the Fill property of each of the shapes from the event arguments of this event.
Andrew Goldenbaum
Andrew Goldenbaum answered on Mar 24, 2026 4:01 PM
Hello Casey,
I have been investigating the behavior you are seeing in this case, but I am not seeing the behavior in which clicking anywhere in a cell toggles the XamCheckEditor within the XamDataGrid. On my end, it is necessary to click the actual checkbox portion of the editor to toggle the checked state.
I am attaching a sample project that demonstrates this behavior. Would it be possible for you to please modify this sample and send it back or provide some additional information about the configuration of your grid such that I can reproduce the behavior you are seeing?
Andrew Goldenbaum
Andrew Goldenbaum
Andrew Goldenbaum answered on Jan 22, 2025 8:19 PM
Hello Fatin,
My team and I have done an initial review of this forum thread, and it appears that there was an oversight – there should be a textStyle property on the igx-ring-series, but it is unfortunately and accidentally not exposed. More on that in a bit.
If possible, and if you are only using a single doughnut-chart ring, I would recommend upgrading to the igx-data-pie-chart control, which you can read about here: https://www.infragistics.com/products/ignite-ui-angular/angular/components/charts/types/data-pie-chart. This, and the igx-pie-chart expose an innerExtent property that you can use to essentially make a doughnut chart, but the igx-data-pie-chart control is the successor to the igx-pie-chart. I noticed you stated that you are using Angular 16.1.29, but you will need to upgrade to a more recent version for the igx-data-pie-chart. This is documented here: https://www.infragistics.com/products/ignite-ui-angular/angular/components/general-changelog-dv#1810-september-2024
You can use the following code with the igx-data-pie-chart to change the font size and make more of a “doughnut” shape:
<igx-data-pie-chart
name="chart"
#chart
[dataSource]="data"
calloutsTextStyle="20pt Verdana"
innerExtent="0.3">
</igx-data-pie-chart>
I have logged the missing textStyle property in our Ignite UI for Angular GitHub page, here: https://github.com/IgniteUI/igniteui-angular/issues/15293. I would recommend following this development item, as it will be updated when progress is made on it and a font style property is exposed. For the time being though, I would recommend continuing with the igx-data-pie-chart or igx-pie-chart.
