30
refreshing xamGrid template column data based on other field.
Normal 0 false false false EN-IN X-NONE X-NONE
HI,
I am using xamGrid and I have the scenario mentioned below.
I have a status column, when the status is changed to a particular status I need to set the follow-up date to null. I wrote the logic to set the follow-up date to null in data bound class (data item class) and using the INotifier property changed but the value in the date controls (Follow-up date) is not getting cleared.
The following are the columns using.
<ig:TemplateColumn Key="StatusId" HeaderText="Status" MinimumWidth="150">
                                            <ig:TemplateColumn.ItemTemplate>
                                                     <DataTemplate>
                                                             <TextBlock Text="{Binding Status}"></TextBlock>
                                                    </DataTemplate>
                                            </ig:TemplateColumn.ItemTemplate>
                                            <ig:TemplateColumn.EditorTemplate>
                                                    <DataTemplate>
                                                             <naiaControls:EditableCombobox Margin="0" MinWidth="100" SelectedValue="{Binding StatusId, Mode=TwoWay}" SelectedValuePath="Id"
                                                             ItemsSource="{Binding Statuses, Source={StaticResource ViewModel}}"/>
                                                    </DataTemplate>
                                            </ig:TemplateColumn.EditorTemplate>
                                   </ig:TemplateColumn>
<ig:TemplateColumn Key="FollowUp" HeaderText="Follow Up Date">
                        <DataTemplate>
                            <TextBlock Text="{Binding FollowUp}"/>
                        </DataTemplate>
                        <DataTemplate>
                            <sdk:DatePicker Margin="0" SelectedDate="{Binding FollowUp, Mode=TwoWay}"/>
                        </DataTemplate>
I checked the row data item value in cell exit edit mode event and it is updated to null.
I am using Infragistics SL 4 v10.3.
Hareen.
Parents
No Data
Reply
  • 30
    Please discard this post, after working on the fresh copy of gird I found that this is issue with ‘INotifyPropertyChanged’.
Children
No Data
