I found this question from many years ago on this forum.
https://www.infragistics.com/community/forums/f/ultimate-ui-for-windows-forms/2920/in-theory---any-issue-developing-netadvantage-2007-vol-1-netadvantage-2007-vol-3-side-by-side-on-the-same-machine
I'd like to know if the same answer applies. My current solution uses V12.??? dll's, and I am looking to move it into the latest version. I'll need to support the current software version using the same machine. I am hoping this is still possible.
Thank you very much.
Hello Gale,
Thank you for posting.Yes the same answer will definitely apply, you can have multiple version in the same machine.
They all will visible in the visual studio Toolbox with a specific versions,I attached an image for your reference but you can not use multiple versions controls in one application otherwise you will get version conflict error.
Please let me know if you need further assistance.
Sincerely,Divya JainAssociate Software Developer
Thank you very much Divya. I was hesitant to push forward with this.
