I am currently using the Release 16.2 and PDF and get the message that PDF-encryption is not supported in this release.
Is it supported in the current release 20.2 ?
#Region "Encryption" Private Sub Encryption_Click(ByVal sender As Object, ByVal e As EventArgs) Handles Encryption.Click ' Encryption is not supported in this release ' 'SetupReportInfo("Report with Encryption") '' Setup Encryption 'report.Preferences.PDF.Encryptor.Password.User = "test" 'report.Preferences.PDF.Encryptor.Password.Owner = "infragistics" 'report.Preferences.PDF.Encryptor.Permissions.Add = False 'report.Preferences.PDF.Encryptor.Permissions.Copy = False 'report.Preferences.PDF.Encryptor.Permissions.Modify = False 'report.Preferences.PDF.Encryptor.Permissions.Print = True 'AddContentToReport("This document is encrypted.") 'PublishReport() 'OpenReport() End Sub#End Region
Thank you and best regards
Hello Gerald,
Unfortunately due to pending government approval regarding export limitations, encryption-related functionality still not supported with V20.2.
