My application uses infragistics control version 10.2 since 5-6 year back.
Now I need to upgrade it to the latest infragistics version.
I need your valuable support on upgrading my application infragistics version.
I have attached a screenshot of the infragistics DLL , which my application currently uses.
Please guide me how to upgrade it .
If I just replace the old DLL file with the new one, is the application still work?
Hi
I have successfully upgraded my application from 10.2 to the 14.2.
Now I am going to release application so I need few information.
Could you please provide the documentation of 14.2 and 15.1 build.
What are new changes and big fixes in 14.2 as well as 15.1 build?
Which is more stable(error free) version of infragistics compare to 10.2?
Thank you
Hi Amit,
Thank you for the reply.
Here is the documentation for 14.2:
http://help.infragistics.com/Doc/WinForms/2014.2/CLR4.0/
And here is the documentation for 15.1:
http://help.infragistics.com/Doc/WinForms/2015.1/CLR4.0/
Note that they are largely the same. The main difference are in the “What’s New” and “Known Issues and breaking changes” pages. Here are these articles for 15.1 (you can see the articles for the older versions, including 14.2 under What’s New -> Revision History):
http://help.infragistics.com/Doc/WinForms/current/CLR4.0/?page=Whats_New_Whats_New_in_2015_Volume_1.html
http://help.infragistics.com/Doc/WinForms/current/CLR4.0/?page=Breaking_Changes_2015_Volume_1.html
The above two articles contain information about what we’ve changed with the release of 15.1. Currently both 15.1 and 14.2 contain all our latest fixes since both versions are supported. So currently they are equally stable. The only difference is that the support for 14.2 will expire sooner than the support for 15.1. For more information, please visit this link:
http://www.infragistics.com/support/product-lifecycle
As for the exact fixes, they are listed with each service release in which they are implemented. We don’t have them available in one single place.
Please let me know if you have any additional questions.
Hello Amit,
I am just checking about the progress of this issue. Let me know if you need my further assistance on this issue.
I have just one question .
how can I get Infragistics version 15.1 update for my visual studio 2010?
If you have the 15.1 version already installed it should be available in your Visual Studio 2010 (the supported VS versions for 15.1 are 2010, 2012 and 2013). If the controls aren’t present in your toolbox you can add them manually by using the Choose Toolbox Items Dialog Box. To do that right click on the Toolbox and select Choose Items from the context menu. From there you can select the 15.1 components and add them to the toolbox.
Let me know if you have any additional questions.
