Hi I have a WebHierarchicalDataGrid with parent-child rows. I want the user to select a row and press a delete button outside of the grid to delete the selected row. Sounds simple. I implemented a javascript function to delete the selected row. It deletes it but right after the delete it gives this error:
Microsoft JScript runtime error: Sys.WebForms.PageRequestManagerServerErrorException: Requested record cannot be found by key.
The error comes fromt he ScriptResource.axd? and is stopped at "throw error;" in the code below:
_endPostBack:
function PageRequestManager$_endPostBack(error, executor, data) {
if (this._request === executor.get_webRequest()) {
this._processingRequest = false;
this._additionalInput = null;
this._request = null; }
var eventArgs = new
Sys.WebForms.EndRequestEventArgs(error, data ? data.dataItems : {}, executor); Sys.Observer.raiseEvent(
this, "endRequest", eventArgs);
if (error && !eventArgs.get_errorHandled()) {
throw error;
Again, it actually deletes the row but afterwards posts the error above.
If I hit the 'Delete' key on my keyboard to delete a row it works without error.
Also, my delete stored procedure that is called on a delete, will delete both records in the parent table and child tables.
Any help would be appreciated. thanks!
klp0
Try turnibg off AutoCRUD. I have had a similar problem and it appears that if AutoCRUD is true then the control tries to delete before or after your delete.
Thanks! It worked for me.
