We are using some Infragistics controls similar to the Infragistics example
…\Infragistics\2013.2\Windows Forms\Samples\ExplorerBar\CS\Collapsible Navigation Pane CS
There is a little problem: Clicking at the ribbon scroll button (see the red circle in my screenshot) at the right side we should get a second scroll button at the left side. But the left button does not appear.
Note: There are some other Infragistics sample projects without this bug. But I do not see the difference in code.
Thank you very much for looking at the bug in that example!
Could you please let me know which exactly version of Infragistics you are using. We have very similar issue with “Pager” when ribbon is in Office2013 style, which is already fixed in the latest service release of Infragistics 13.2 and 14.1.
http://www.infragistics.com/community/forums/t/29398.aspx
I am waiting for your feedback.
It is 13.2.20132.2010
Thank you!
Hello ,
I’ve tested this scenario with Infragistics 13.2 service release 2042 and everything works properly . In the attached archive you will find sample which I’ve tested and small video of my test. So please upgrade your solution to the latest service release of Infragistics 13.2.
Please let me know If you have any further questions.
Ok, thanks!
I can test this in 2 weeks.
Please let me know when you are done with your tests and if you have any further questions.
Thank you for using Infragisitcs Components.
