60
Dialogbox div render twice when page loads
Hi, My codes are as below in as mvc view.
<input type="button" name="btnOpen" id="btnOpen" value="Open Dialog" />
<%= Html.Infragistics()
.Dialog()
.ContentID("divDialog")
.State(DialogState.Closed)
.Modal(true)
.Height("740px")
.Width("1040px")
.CloseOnEscape(true)
.Resizable(false)
.Draggable(false)
.Render() %>
<div id="divJobs">
   <script>
     alert('test');
     </script>
</div>
When page is load it fires two times.
Is that bug? Does anyone have idea about this?
Thanx
Dharmendra
Parents
No Data
Reply
  • 60
    Suggested Answer
    Finally I ended up to not to go with igDialog instead I used jquery dialogbox.
    I found that jquery dialogbox is having same issue but there is  a solution. On button click I have removed the script tag by finding it from dialogbox before opening it and everything works well.
    $("#btnOpen").click(function () {
             $("#DivPickInstr").find("script").remove(); //Did the trick hope this help some one :)
             $("#DivPickInstr").dialog({
                   model: true,
                   height: 650,
                   width: 950,
                   resizable: false,
    Thank you,
    Dharmendra Mistry
Children
No Data
