I'm using a xamDataGrid with the undo redo framework and if a cell within a row has been edited I'd like to set the row to a different color. If possible when the user clicks Undo I'd like the row to revert to its standard colour - Can I tap into the undo/redo events or is there a better option?
Many thanks!
Hello Michael,
Thank you for your post. I have been looking into it and I created a sample project for you with the functionality you want. Basically I handled the CellChanged event and in the handler I change the Background of the changed Record. I also handled the DataValueChanged event and in its handler I check if Undo is performed via Boolean variable I created and if yes I return the Background to transparent. Please let me know if you need further clarifications on this matter.
Hi Stefan,
That is exactly what I needed thank you very much :)
Thanks again.
