Hello Amyn,
Thank you for contacting Infragistics.
You will need to install Infragistics 2008 Volume 3 in order to be able to use the designers. We do not have a trial installer for that version available.
You have two options available. You could install the trial of Infragistics 2014 Volume 1 and use the Version Utility to upgrade the Infragistics references or you could purchase Infragistics 2014 Volume 1 and ask sales for a key for Infragistics 2008 Volume 3.
Also if i were to download the setup file for Infragistics without upgrading, can you tell me which one to download from this link?
http://www.infragistics.com/products/downloads/archived
P.S. I am not using ASP.NET in my application. It is a windows form based application.
Thank you.
Thank you for your response.
The page at the following link describes how to use the Version Utility.
http://help.infragistics.com/doc/WinForms/2014.1/CLR4.0/?page=Win_Upgrading_a_Project_to_Infragistics_Windows_Forms_11.1_(and_above)_Using_Version_Utility.html
If you do not see Infragistics 2008 Volume 3 listed at https://www.infragistics.com/my-account/keys-and-downloads/, then you will need to register your product key.
We do not offer an installer for Infragistics 2008 Volume 3 for Windows Forms on the archived products page. The only way to get the installer is to have registered a product key.
Please let me know if you have any other questions.
Ok so I do have they key for NetAdvantage Select 2008 Vol 3 but I would like to know if the key would still be valid for use? And can that key be used on multiple machines?
P.S. I also have the key for Infragistics Professional 2013 Vol 2. But I would rather prefer not to upgrade my project.
My previous problems have all being resolved.
Now I have another issue. My application run perfectly when I build the project in 100% dpi and run at 100% dpi but when I change the DPI (from 100%-125%), one of the pane does not resize automatically unless it gets focus.
And when I reopen the form in designer mode at 125% DPI and run at 125% DPI, it works fine but when I change back to 100% dpi, same problem occurs.
Any suggestion
I believe this was an issue with our older versions of Infragistics. If possible, make a copy of your project and upgrade the copy to Infragistics 2013 Volume 2. Let me know if the upgraded copy reproduces the issue.
Please let me know if you have any other questions about this.
I have upgraded my entire project to NetAdvantage_WinForms_2013. I cleaned my entire project and build it again and the issue is still there. I haven't made any changes to my code after the upgrade.
