I'm using Infragistics 2010.3 in my application. So far it is good without having any problem. When I tested in Internet explorer version 11. The webdatepicker control is showing blank even when I set a default value. But when I click a small down arrow mark the month calendar is getting opened and show the selected date. But not showing that value in the date picker. Also once a date is selected in Month calendar it is not showing in the web date picker. It is displaying blank. Let me know how can I fix this.
I am just following up to see if you need further assistance on this.
Hi Kolev,
Thanks for following up. I installed the latest version of Infragistics 2013.2. But my application is running in .NET3.5 and unable to use the newer version. Can you suggest how to use the latest version in .NET 3.5 runtime versions.
Hello Agilan,
I wanted to let you know that 12.2 is the last release for CLR 3.5 assemblies. CLR 2.0 and CLR 3.0 assemblies are supported through May 2013 for bug fixes and through May 2015 for general support issues. For more information please have a look at the following reference:
http://www.infragistics.com/community/blogs/jason_beres/archive/2012/05/29/updated-support-for-clr-versions-and-visual-studio-versions.aspx
Related references:
http://www.infragistics.com/community/forums/t/86092.aspx
Could you please provide the download link for 2012.2. i could not able to find the 2012.2 version
Let me know If I may be of further assistance.
