Dear Sir,
This is Manoj , I use WebDataGrid to Create multi header column in my web page. When is use Group Field in aspx page . It shows some error that is
"Group Field is not a Known element . This can occur if there is a compilation error in the Website or the web.config file is missing"
Kindly let me know immediately .
I Had a work to finish.......
Manoj
Hello Manoj,
Thank you for contacting Infragistics. I have done some looking into this matter and have created a sample. I have been unable to reproduce this behavior. I am using v14.1 service release 2150. What version are you using? What browsers do you see this in? What happens when you run my sample? Can you provide me with an isolated sample that reproduces this issue?
Note I have removed the bin and ig_res folder for file size. Looking forward to hearing from you.
Thanks Mike,
I am using version 12.1 service release so its not working and i need the code which you sent to me in the format of aspx.cs file.
can u help me
