Extra Vertical and Horizontal scroll bar is appearing on Infragistics grid
Hello Priyanka,
I am checking about the progress of this issue.
Please let us know if you need any further assistance.
Thank you for using Infragistics Components!
As far as I understand you, you have tried Mike`s suggestion and it is not works for you. Can you please let me know if the grid is into a container like Panel component? Are you abele to scroll UltraGrid Rows with both vertical scrollbars? Have you tried to isolate this in a separate sample?
I am waiting for your response.
Yes.I am abele to scroll UltraGrid Rows with both Horizontal scrollbars.But UltraGrid is not in Panel.
Note:After refresh UltraGrid showing properly.
I am glad you managed to solve your issue.
Let us know if you need any further assistance related to it.
Provided solution is not working.
Based on your last answer, I got the impression that you have managed to solve your issue after refreshing the UltraGrid. Since Mikes`s approach is not working for you I need more information about the scenario in which you are using the UltraGrid. The most appropriate and self-explanatory way of showing me your issue is to isolate it in a sample project and upload it to your next forum post.
I am just checking about the progress of this issue. Let me know if you have any questions related to it.
