2325
QuickAccessToolbar Textbox Tool foreground font issue
I have version 13.1 and I have a QAT with a textbox tool on it.  When I type in the textbox you can barely see it the foreground color looks like silver or something... however taking the focus off the textbox the foreground color turns black and you can read it fine.  How can i change the foreground color of the text for when the textbox has focus?
I am using the QAT on winform.
Parents
No Data
Reply
  • 48586
    I was able to reproduce this on my side and I found that if you set IsGlassSupported = false; , you will avoid this issue. So I’ve created support ticket in our issue taking system for further investigation of this matter. The ID of your support ticket is CAS-144661-Q5Y1J6, and I will update you about the progress of my research via the case.
Children
