I used ultrawingrid excel exporter with RowLayoutGroupInfo and i got Object reference error.
If I don't use RowLayoutGroupInfo and i can export to excel successfully.
I used 11.1.20111.1003 version.
Kindly advice.
Below are the stack trace.
at Infragistics.Win.UltraWinGrid.UltraGridBand.GetSummaryLayoutPreferredSize(SummaryDisplayAreaContext context) at Infragistics.Win.UltraWinGrid.SummaryValuesCollection.GetFixedSummaryLineHeight(SummaryDisplayAreaContext context, Int32 level) at Infragistics.Win.UltraWinGrid.SummaryValuesCollection.GetFixedFooterAreaHeight(SummaryDisplayAreaContext context) at Infragistics.Win.UltraWinGrid.SummaryValuesCollection.GetSummaryFooterHeight(SummaryDisplayAreaContext context) at Infragistics.Win.UltraWinGrid.UltraGridSummaryRow.get_BaseHeight() at Infragistics.Win.UltraWinGrid.UltraGridRow.get_TotalHeight() at Infragistics.Win.UltraWinGrid.VisibleRow.GetTotalHeight(Boolean adjustForOverlappedBorders) at Infragistics.Win.UltraWinGrid.VisibleRow.GetTotalHeight() at Infragistics.Win.UltraWinGrid.RowScrollRegion.IsRowFullyVisible(ScrollbarVisibility colScrollbarVisibility, VisibleRow visibleRow) at Infragistics.Win.UltraWinGrid.RowScrollRegion.IsFirstScrollableRowVisible(ScrollbarVisibility colScrollbarVisibility) at Infragistics.Win.UltraWinGrid.RowScrollRegion.IsFirstScrollableRowVisible() at Infragistics.Win.UltraWinGrid.RowScrollRegion.ResetScrollInfo() at Infragistics.Win.UltraWinGrid.RowScrollRegion.RegenerateVisibleRows(Boolean resetScrollInfo) at Infragistics.Win.UltraWinGrid.RowScrollRegion.RegenerateVisibleRows() at Infragistics.Win.UltraWinGrid.RowScrollRegion.WillScrollbarBeShown(ScrollbarVisibility assumeColScrollbarsVisible) at Infragistics.Win.UltraWinGrid.ScrollRegionBase.WillScrollbarBeShown() at Infragistics.Win.UltraWinGrid.DataAreaUIElement.AddIntersectionHelper(UIElementsCollection oldElements, RowScrollRegion rsr, ColScrollRegion csr, RowScrollRegion rsrPrevious, ColScrollRegion csrPrevious, Boolean lastVisibleRsr, Boolean lastVisibleCsr) at Infragistics.Win.UltraWinGrid.DataAreaUIElement.PositionChildElements() at Infragistics.Win.UIElement.VerifyChildElements(ControlUIElementBase controlElement, Boolean recursive) at Infragistics.Win.UltraWinGrid.DataAreaUIElement.VerifyChildElements(ControlUIElementBase controlElement, Boolean recursive) at Infragistics.Win.UltraWinGrid.DataAreaUIElement.set_Rect(Rectangle value) at Infragistics.Win.UltraWinGrid.UltraGridUIElement.PositionChildElements() at Infragistics.Win.UIElement.VerifyChildElements(ControlUIElementBase controlElement, Boolean recursive) at Infragistics.Win.UltraWinGrid.UltraGridUIElement.VerifyChildElements(ControlUIElementBase controlElement, Boolean recursive) at Infragistics.Win.UIElement.VerifyChildElements(Boolean recursive) at Infragistics.Win.UltraWinGrid.UltraGridUIElement.InternalInitializeRect(Boolean verify) at Infragistics.Win.UltraWinGrid.UltraGridLayout.InternalInitializeUltraGridUIElementRect(Boolean verify, Boolean onlyWhenEmpty) at Infragistics.Win.UltraWinGrid.RowsCollection.SyncRows() at Infragistics.Win.UltraWinGrid.RowsCollection.EnsureNotDirty() at Infragistics.Win.UltraWinGrid.RowsCollection.get_Count() at Infragistics.Win.UltraWinGrid.UltraGridBand.GetRowSelectorNumberWidth() at Infragistics.Win.UltraWinGrid.UltraGridLayout.GetRowSelectorWidthDefault(UltraGridBand band) at Infragistics.Win.UltraWinGrid.UltraGridBand.get_RowSelectorWidthResolved() at Infragistics.Win.UltraWinGrid.UltraGridBand.get_RowSelectorExtent() at Infragistics.Win.UltraWinGrid.UltraGridBand.GetExtentLayout(Boolean minimum, BandOrigin bandOrigin) at Infragistics.Win.UltraWinGrid.UltraGridBand.GetExtentLayout() at Infragistics.Win.UltraWinGrid.UltraGridGroup.CalcLayoutHelper(Int32 bandExtent) at Infragistics.Win.UltraWinGrid.UltraGridGroup.CalcLayoutHelper() at Infragistics.Win.UltraWinGrid.UltraGridGroup.VerifyRowLayoutCache() at Infragistics.Win.UltraWinGrid.UltraGridBand.VerifyRowLayoutCache() at Infragistics.Win.UltraWinGrid.UltraGridBand.get_LayoutOrderedVisibleColumnHeaders() at Infragistics.Win.UltraWinGrid.UltraGridBand.GetAllOrderedHeaders() at Infragistics.Win.UltraWinGrid.UltraGridBand.CalculateBandMetrics(UltraGridBand priorBand) at Infragistics.Win.UltraWinGrid.BandsCollection.CalculateBandMetrics(Int32 pass) at Infragistics.Win.UltraWinGrid.BandsCollection.CalculateBandMetrics() at Infragistics.Win.UltraWinGrid.ColScrollRegionsCollection.InitializeMetricsHelper() at Infragistics.Win.UltraWinGrid.ColScrollRegionsCollection.InitializeMetrics() at Infragistics.Win.UltraWinGrid.UltraGridLayout.ApplyLoadedBands() at Infragistics.Win.UltraWinGrid.UltraGrid.Export(IUltraGridExporter exporter) at Infragistics.Win.UltraWinGrid.ExcelExport.UltraGridExcelExporter.Export(UltraGrid grid, Worksheet worksheet, Int32 startRow, Int32 startColumn) at Infragistics.Win.UltraWinGrid.ExcelExport.UltraGridExcelExporter.Export(UltraGrid grid, WorkbookFormat workbookFormat) at Infragistics.Win.UltraWinGrid.ExcelExport.UltraGridExcelExporter.Export(UltraGrid grid, String fileName, WorkbookFormat workbookFormat) at Infragistics.Win.UltraWinGrid.ExcelExport.UltraGridExcelExporter.Export(UltraGrid grid, String fileName) at nSolution.mdiMain.ExportExcelByUltraGrid(Object ugExcel, String strFileName) in D:\PROJECTS\nSolution\nSolution\nSolution\nSolution\mdiMain.vb:line 2162
Hello Naning,
I saw you had opened another forum thread with same question here http://www.infragistics.com/community/forums/t/92353.aspx
Please follow the link above to see my answers.
