1770
Dynamically setting ItemsProvider in code behind for xamComboBox
I have a couple of questions.
i want to use the same xamdatagrid for several different data sources. The reason is that  only a few data columns differ. The others are the same. instead of defining two different data grids in xaml and styling the columns there I use the same one and I style the fields in the code behind. So I have
private void OnFieldLayoutInitialized(object sender, FieldLayoutInitializedEventArgs e)
if(gridtype1){
var vgDownStyle = new Style(typeof(XamComboEditor));
vgDownStyle.Setters.Add(new Setter(XamComboEditor.ItemsProviderProperty, new DynamicResourceExtension("ValveGroupList1")));
vgDownStyle.Setters.Add(new Setter(XamComboEditor.DisplayMemberPathProperty, new DynamicResourceExtension("ValveGroupName")));
e.FieldLayout.Fields["VG"].Settings.EditorStyle = vgDownStyle;
}else if (gridtype2) {
vgDownStyle.Setters.Add(new Setter(XamComboEditor.ItemsProviderProperty, new DynamicResourceExtension("ValveGroupList2")));
e.FieldLayout.Fields["ValveGroupList2"].Settings.EditorStyle = vgDownStyle;
is the above code the same as
<ComboBox Grid.Row="1
ItemsSource="{Binding ValveGroupList1}"
DisplayMemberPath="ValveGroupName"
In terms of the bolded text?
If so it's not binding.
second question is (in the same event method as above)
If I have a loop
foreach (var field in e.FieldLayout.Fields)
is there a way to loop only through fields that contain a specific character?
Parents
No Data
Reply Children
