I've got an UltraWinGrid hooked up to a BindingSource.
One of my source's columns/properties is of type Nullable(Of Integer).
I have set the column's ValueList property, and the ValueList includes an entry generated by the line "ValueList.ValueListItems.Add(DBNull.Value, "")"
I have set the following settings on the Column:
Column.ValueList = MyValueList Column.NullText = String.Empty Column.Format = String.Empty Column.Nullable = Infragistics.Win.UltraWinGrid.Nullable.Nothing Column.Style = Infragistics.Win.UltraWinGrid.ColumnStyle.DropDownList Column.Header.Caption = "myCaption"
In my dropdown, when the list is dropped down, the blank value shows as an empty option in the list. If I select this option and the cell is still selected, an empty cell is displayed.
When I click off the list, the cell suddenly displays a "0". When I re-focus the cell and the dropdown opens again, the 0 is still displayed in the cell itself, but the entry in the dropdown list is still a blank entry. Clicking on the blank entry again blanks the cell again, until it loses focus, when it displays 0 again.
I've searched the forum and I can't find any solution except for this guy http://www.infragistics.com/community/forums/t/75962.aspx and he doesn't say how he solved his problem.
EDIT: I've just noticed that the "DisplayString" of the ValueList item is being set to "0" instead of an empty string, which I suspect is the root of the problem, but I'm not sure how to deal with it.
There's no "DisplayString" property on ValueListItem. I assume you mean DisplayText?
Fixing this is probably just a matter of changing the DisplayText. The DisplayText of the item is whatever you set it to when you populated the ValueList, or if you bound the ValueList to a DataSource, then it comes from the DisplayMember property in your data.
If that's not helpful, then perhaps you could post a small sample project demonstrating the problem and I would be happy to take a look at it.
BTW... is there any particular reason you are using Nullable(Of Integer) instead of just Integer? If your data source is a DataSet, DataTable, or UltraDataSource (with or without a BindingSource), then you don't need to use a Nullable type - the data source will already allow you to support nulls.
Thanks for the reply.
I find ValueItem.DisplayString when examining the problematic ValueItem in the debugger. This exposes a ReadOnly Friend Property of the ValueItem, called "DisplayString".
This DisplayString field is String.Empty at the time the relevant ValueItem is created, and it is still String.Empty after I set Column.ValueList = myValueList, but at some point (presumably when the WinGrid is being displayed) it is this field that is being set to "0". ValueItem.DisplayText is never set to "0", it always remains as String.Empty.
We don't use DataTable here because of legacy issues with database communication methods. We're evaluating switching to another data access method, but for the moment we use an in-house data container.
I'm binding that to the grid via:
Private myDataMappings As List(Of DataMapping) Dim myBindings As New System.ComponentModel.BindingList(Of DataMapping)(myDataMappings) Dim mySource As New Windows.Forms.BindingSource() mySource.AllowNew = True mySource.DataSource = myBindings grdMyMappings.DataSource = mySource
and allowing the WinGrid to bind to the Properties of the object.
Like I said, though, DisplayText of the ValueItem is always String.Empty. It is the ReadOnly Friend Property DisplayString that is being set to "0", and I can't work that out at all.
Hello Kristian,
Thank you for contacting Infragistics Support.
To set the ValueList item display text you may use a code like this:
MyValueList.ValueListItems(10).DisplayText = String.Empty
where 10 is the index of the item with value of Null in your value list items collection. More about ValueList you can find by following the next link http://help.infragistics.com/Help/Doc/WinForms/2014.2/CLR4.0/HTML/Infragistics4.Win.UltraWinGrid.v14.2~Infragistics.Win.UltraWinGrid.UltraGridColumn~ValueList.html
Please find attached a sample solution and let me know if this is what you are looking for or if I am missing something.
Thanks for your reply, Miko.
As I said in my last posting, the .DisplayText property of the problematic ValueListItem always remains as String.Empty. The issue appears to be the Friend ReadOnly Property DisplayString, which is somehow getting set to "0", even though DisplayText remains as String.Empty.
Hmm...
I have played with your solution Miko, thank you for providing it.
I have found that the following code will reproduce what I am seeing in the debugger:
Dim NullValue As New ValueListItem(DBNull.Value, String.Empty) NullValue.DataValue = 0 MyValueList.ValueListItems.Add(NullValue)
Observing NullValue in Visual Studio shows me that DataString is set to "0" and DataText is set to String.Empty.
However, when the dropdown is displayed, both the dropdown and the cell display "0". In my project, only the cell displays "0".
Strange.
Thank you for your feedback.
DisplayString property of ValueListItem represents the DataValue as string, e.g. DataValue.ToString(). If you set the DisplayText property of ValueListItem to null or empty string the DisplayString will be shown instead of the DisplyText. If you actually need to display empty string as display text in your ValueList you may set the DisplayText property to “ “ (a white space).
I am just checking about the progress of this issue. Let me know if you need my further assistance on it.
Hi, Milko,
I'm afraid I had to go with writing a quick and dirty function to dump all the data out to a DataTable.
I couldn't get around the issue I was having, but I also couldn't reproduce it using anything other than our data objects, so I guess the problem must be with them.
You can consider this question closed.
