1750
Child list with nested classes
Hello community!
I have a problem with displaying hierarchical data which I retrieve from a database. For the example app I have built a simpler example:
MyComponent has a list of ComponentToMaintenance (1:n)
ComponentToMaintenance has an ID, and references MyComponent and MaintenanceTask. ComponentToMaintenance resolves the (M:N) relation between MyComponent and Maintenance Task
MaintenanceTask references MaintenaceInterval (n:1)
I load the object structure into an observable collection. The content is displayed in the grid including the '+' as indicator that child entries could be found. If I click on the expansion sign, I see the list with the correct amount of the child entries. The problem is, that the property values are not displayed for the child entries.
Attached please find the sample solution "GridProblemChildGrandChild.rar".
In the project "GridViewProblem.Shared\DataClasses" you find the classes for my datastructure.
In "GridViewProblem\ViewModel" I create the data in the method "GenerateTestData"
Thank you for your help.
Parents
No Data
Reply
  • 14517
    In order to display the properties in the objects, My Component and Maintenance Task, within the child rows you can use an UnboundField and set the binding path to  <objectname>.<propertyname>. For example:
    <igDP:UnboundField BindingPath="AssignedComponent.ComponentID" Label="Component ID"/>
    Please see modified sample.
    Sincerely,
    Valerie
    Developer Support Supervisor - XAML
    www.infragistics.com/support
    GridViewProblem.zip
Children
