How does one enable/disable sorting of columns on client the client?
When a Row Edit Template is opening I want to disable grid behaviors so that features such as sorting cannot be performed while editing a row. Conversely when the Row Edit Template is closed I want to enable sorting (but only for those columns that were originally sortable). I could not find anything obvious in the sorting behavior collection.
Hello.
Thank you for contacting us.
About your concerns, when the template is opened you wont be able to apply sorting to any of the columns, this behavior is by design provided by our WebDataGrid. Could you please let me know if you are facing behavior other than mentioned above?
Thanks Zdravka, indeed the sorting is not applied as you stated. I misunderstood a colleague.
The problem is when the row edit template is open and a cell within the grid is clicked the RET is closed. The grid has Activation and Selection behaviors. If the Activation behavior is removed the RET will remain open when another cells is clicked.
Can the Activation behavior be added and removed on the client?
