I have two questions:
1 - Can I use sorting with ObjectDataSource?
2 - Can I use ObjectDataSource and ig:BoundDataField referencing a field from a related table in DataFieldName?
Please help me, I am not figuring out how to do this!
Thanks in advance!!
Edson
Hello Edson,
ObjectDataSource is not supported for automatic sorting. DataView, DataTable and DataSet are.
For the second part I don't see any issue with defining a BoundDataField for the grid, without having auto generated columns.
Is that what you are asking?
Boris, thank you for the quick response!!
About the second issue: I have two tables related by a foreign key, like Cities and Countries. The code have two classes mapped with the same name, I am using an ObjectDataSource and the TypeName points to Cities, but I need to bind the CountryName field from the Country table and display it. If I use ListView standard control from Visual Studio I have all the classes related to Cities available using the local variable automatic created "Item" or BindItem.
Please, take a look at the two samples attached, one with WebDataGrid and the other with ListView so you can see what I need and if it's possible with WebDataGrid. I want to replace list view with WebDataGrid.
Last question: Does WebDatGrid supports ModelBinding?
