50
Copy row to a new row
I want to copy a row into a new row when the user click a button placed on each row in a "copy button column" of a WebHierarchicalDataGrid. The grid has a depth of 2 bands, and I want to be able to copy any of the child band into a new row at the bottom of the band. How can I do that?
I've looked many workaround and now I'm using clipboard to copy/paste the row, but I am unable because I cannot select the last row of the band (how may I do that?) and I have to set the unique ID of the added line (I don't know how, I know I have to remember the unique ID).
Thanks!
Parents
  • 50
    I precise I add a row at the bottom of the band. Some more détails about actual code:
    Grid in .aspx:
    <ig:WebHierarchicalDataGrid ID="whdg" runat="server" AutoGenerateBands="False" AutoGenerateColumns="False" DataKeyFields="ref_ADC_id" Height="600px" InitialDataBindDepth="-1" Key="Niv1" Width="95%" StyleSetName="Default">
    <ClientEvents Click="whdg_ContainerGrid_Click" />
    <Columns>
    <ig:BoundDataField DataFieldName="ref_ADC_id" Key="ref_ADC_id" Hidden="true" Width="65px" />
    <ig:BoundDataField CssClass="Cell_Right_Niv2" DataFieldName="code" Key="code" Width="25px">
    <Header CssClass="Entete_Right" Text="Ordre" />
    </ig:BoundDataField>
    ... (other BoundDataFields)
    <ig:BoundDataField CssClass="Cell_Right_Niv2" DataFieldName="quantite" Key="quantite" Width="50px">
    <Header CssClass="Entete_Right" Text="Quantité" />
    </Columns>
    <Behaviors>
    <ig:Selection CellClickAction="Row" Enabled="true" RowSelectType="Single" />
    <ig:Activation>
    </ig:Activation>
    <ig:EditingCore>
    <EditingClientEvents RowAdding="Grid_RowAdding" />
    <Behaviors>
    <ig:CellEditing/>
    <ig:RowEditing/>
    <ig:RowDeleting>
    </ig:RowDeleting>
    </Behaviors>
    </ig:EditingCore>
    <ig:Clipboard/>
    <ig:RowSelectors>
    </ig:RowSelectors>
    </Behaviors>
    <Bands>
    <ig:Band AutoGenerateColumns="false" DataKeyFields="heureID" DataMember="Niv2" Key="Niv2" ShowHeader="true">
    <Columns>
    <ig:BoundDataField DataFieldName="heureID" Key="heureID" Hidden="true" Width="65px" />
    <ig:TemplateDataField CssClass="Cell_Center" Key="Copy" Width="20px">
    <Header CssClass="Entete_Center" Text="" />
    <ItemTemplate>
    <asp:Image ID="imgCopy" ToolTip="Copier" runat="server" ImageUrl="img/Copier.png" CssClass="imgClickYes" />
    </ItemTemplate>
    </ig:TemplateDataField>
    <ig:TemplateDataField CssClass="Cell_Center" Key="Delete" Width="20px">
    <ItemTemplate>
    <asp:Image ID="imgDelete" ToolTip="Supprimer" runat="server" ImageUrl="img/Supprimer.png" CssClass="imgClickYes" OnClientClick="DeleteRow(); return false;" />
    </ItemTemplate>
    <ig:BoundCheckBoxField CssClass="Cell_Center" DataFieldName="isLivrable" Key="isLivrable" Width="50px" />
    </Columns>
    <Behaviors>
    <ig:EditingCore Enabled="true" EnableInheritance="true" AutoCRUD="false" BatchUpdating="True">
    <Behaviors>
    <ig:CellEditing Enabled="true" EditModeActions-EnableF2="true" EnableInheritance="true" EditCellCssClass="Cell_LeftBlueEnabled">
    <ColumnSettings>
    <ig:EditingColumnSetting ColumnKey="code" ReadOnly="false" />
    <ig:EditingColumnSetting ColumnKey="nom" ReadOnly="false" />
    </ColumnSettings>
    <EditModeActions EnableOnKeyPress="True" MouseClick="Double" />
    </ig:CellEditing>
    <ig:RowAdding AddNewRowCssClass="Cell_LeftBlueEnabled" EditCellCssClass="Cell_LeftBlueEnabled" EnableInheritance="True">
    <AddNewRowClientEvents EnteringEditMode="Grid_RowAdding_EnteringEditMode" />
    <EditModeActions EnableOnKeyPress="True" />
    </ig:RowAdding>
    <ig:RowDeleting ButtonHtml="Delete" ShowDeleteButton="false">
    </ig:RowDeleting>
    </Behaviors>
    </ig:EditingCore>
    <ig:RowSelectors RowNumbering="True" Enabled="true">
    </ig:RowSelectors>
    </Behaviors>
    </ig:Band>
    </Bands>
    </ig:WebHierarchicalDataGrid>
    The function that handles to Copy button click event - note that delete button seems to work:
    function whdg_ContainerGrid_Click(sender, eventArgs) {
    if (eventArgs.get_type() == "cell") {
    var columnKey = eventArgs.get_item().get_column().get_key()
    switch (columnKey) {
    case "Delete":
     var grid = sender;
    var gridRows = sender.get_rows();
    var row = eventArgs.get_item().get_row();
    var selectedRows = grid.get_behaviors().get_selection().get_selectedRows();
    for (var i = selectedRows.get_length() - 1; i >= 0; i--) {
    var row = selectedRows.getItem(i);
    gridRows.remove(row);
    break;
    case "Copy":
    var grid = sender;
    var rowsLength = grid.get_rows().get_length();
    var row = new Array(myRowUniqueID);
    var clip = sender.get_behaviors().getBehaviorByName('Clipboard');
    clip.copy();
    sender.get_rows().add(row);
    clip.paste(); //manque juste á coller dans la bonne row
    break;
Reply Children
