I am upgrading the infragistics version from 11.1 to 13.2 and in my webhierarchical data grid there is a radio butto under template column and i need to handle the click event of radio button.
Which was possible in ClickCellbutton event of ultrawebgrid .
Please can you let me know its equivalent.
Thanks in Advance
To replace the ClickCellButton I recommend you use the Click event of the WebDataGrid. To set it up you would go into the ClientEvents collection of the WebDataGrid:
http://help.infragistics.com/doc/ASPNET/2014.2/CLR4.0/?page=Infragistics4.Web.v14.2~Infragistics.Web.UI.GridControls.GridClientEvents~Click.html
In the event itself you can call args.get_type(); to see if the object clicked was a cell, row, header, or footer.
Please let me know if you have any further questions concerning this matter.
Hello Mike,
i am not able to see the events in code behind as they are client events.
I need to handle the click event of the radio button which is placed under the template column.
As soon as it is checked i need to perform server side operation and show the data of the selected row in a new frame.
Priyanka
