With version 14.2.20142.2140 of the igGrid. When using column fixing plus row virtualization and binding data with the igGrid("dataSourceObject") and igGrid("dataBind") method, the first column after the fixed column is converted to a checkbox column. Please see attached sample. if data binding is done on grid initialization it works as expected.
According to this link, http://help.infragistics.com/doc/jQuery/2014.2/CLR4.0/, columnfixing and row virtualization is now supported.
Is there a workaround for this?
Hello Jeff Ducharme,
Thank you for posting in our forums!
I am able to reproduce this issue using the code you provided. I will need a little more time to investigate this issue.
I will have another update for you tomorrow.
After some testing, the Product ID column is actually being rendered as the rowSelectors and not as a checkbox column. I have also discovered that this does not occur when setting the virtualizationMode option to "fixed" instead of "continuous". You can disable rowSelectors or use fixed virtualization as a workaround for now.
I have created a support case for you with an ID of CAS-150276-G4J4S1. The matter has been determined to be a development issue and has been logged in our tracking system with ID: 187995.
I will leave this case open and update you with any new information. You can view the status of the development issue connected to this case by going to the “Account” tab on our website, selecting "My Support Activity" and then this support case will be listed there. Then, you may select the "Development Issues" tab to view details of this development issue.
