3475
WebHierarchicalDataGrid using RowEditingTemplate in the Child row
I have a WHDG that is using the RowEditingTemplate to populate the child row (one band).  The template contains a DropDownList.  I need to populate the DDL in code with the values.  I cannot find the DDL in the grid in the code behind.  I have done this successfully before with a WebDataGrid using the following code.
Dim dropDownList As DropDownList
dropDownList = CType(wdgLoanEstimate.Behaviors.EditingCore.Behaviors.RowEditTemplate.TemplateContainer.FindControl("ddlLoanCostGroupValue"), DropDownList)
For the WHDG I am using the following.  There are no controls in the TemplateContainer even though by RowEditTemplate contains my ClientBindings and the controls are visible on the template when executed.
dropDownList = CType(whdgLoanEstimate.GridView.Bands(0).Behaviors.EditingCore.Behaviors.RowEditTemplate.TemplateContainer.FindControl("ddlLoanCostGroupValue"), DropDownList)
    <ig:WebHierarchicalDataGrid ID="whdgLoanEstimate" runat="server"
        DataKeyFields="LoanCostTypeValue"
        InitialDataBindDepth="1"
        InitialExpandDepth="1"
        Style="z-index: 102; left: 0px; position: absolute; top: 26px"
        Width="760px">
        <Bands>
                  <ig:Band  Key="LoanAppEstimateCostRecID"
                DataMember="LoanCostItemChild"
                DataKeyFields="LoanAppEstimateCostRecID"
                AutoGenerateColumns="false"
                ExpansionColumnCss="GridExpandColumnNone">
                <Behaviors >
                    <ig:EditingCore >
                        <Behaviors >
                            <ig:CellEditing Enabled ="true"  ></ig:CellEditing>
                            <ig:RowAdding AddNewRowCssClass ="hideRowTemplate"></ig:RowAdding>
                            <ig:RowEditingTemplate CancelButton ="buttonCancel" OKButton ="buttonOK">
                                <EditModeActions MouseClick ="Single" />
                                <ClientBindings >
                                    <ig:RowEditingClientBinding ColumnKey ="LoanCostGroupValue" ControlID ="ddlLoanCostGroupValue"
                                        GetValueJavaScript="$get({ClientID}).value"
                                        SetValueJavaScript="$get({ClientID}).value={value} == null ? '' : {value}" />
                                </ClientBindings>
                                <Template>
                                    <div style="background-color:white;border:1px solid black;  ">
                                        <table border="0" >
                                    <tr>
                                        <td>
                                            <asp:Label ID="lblLoanCostGroupValue" runat="server" Text="Group" />
                                        </td>
                                        <td>
                                            <asp:DropDownList ID="ddlLoanCostGroupValue" runat="server"
                                                style="z-index: 100000;"></asp:DropDownList>
                                        </td>
                                    </tr>
                                    <tr>
                                        <td>
                                            <asp:Button ID="buttonOK" runat="server"
                                                OnClientClick="return"
                                                Text="OK"
                                                UseSubmitBehavior="False" />
                                            <asp:Button ID="buttonCancel" runat="server"
                                                CausesValidation="False"
                                                Text="Cancel"
                                        </td>
                                    </tr>
                                </table>
                                    </div>
                                </Template>
                            </ig:RowEditingTemplate>
                        </Behaviors>
                    </ig:EditingCore>
                </Behaviors>
           </ig:Band>
        </Bands>
    </ig:WebHierarchicalDataGrid>
Parents Reply Children
No Data
