I'm migrating a UltraWebGrid to webdatagrid v11.2 but I can not get the igtbl_getCellById of a cell of a webdatagrid infragistics v11. and link it to a similar reference is disabled help please
function ClickBTabla(gridName, cellId){
var cell = igtbl_getCellById(cellId); //aqui genera el error (Microsoft JScript runtime error: Object expected) var renglon = igtbl_getRowById(cellId);
switch(cell.Column.Key)
//mostrar otro formulario
Thank you very much for the prompt reply Hristo A raises the following question I hope you can help me thank you very much in advance
My code is as follows
it is a User Control and my board if loading data
<ig:WebDataGrid ID="TablaGrid" runat="server" Height="350px" Width="400px" HeaderCaptionCssClass="Header" AutoGenerateColumns="False"> <Behaviors> <ig:EditingCore AutoCRUD="false"> <Behaviors> <ig:RowAdding Enabled="false" AddNewRowCssClass="stylenewbox" /> </Behaviors> </ig:EditingCore> </Behaviors> <Behaviors> <ig:Paging PagerMode="NumericFirstLast" PageSize="1000000000"> </ig:Paging> </Behaviors> <ClientEvents Click="ClickBTabla" DoubleClick="TablaGrid_DblClickHandler" /> </ig:WebDataGrid>
the columns to be loaded are specified from the server side.
the question is whether the <ClientEvents Click = "ClickBTabla" DoubleClick = "TablaGrid_DblClickHandler" />
in automatic corresponding values are sent to my function as probe you sent me in response and my value is null. or do I need to specify which columns should show from design. or that's what I need. not that I'm doing wrong my function remains the same
ClickBTabla function (gridname, cellid) {
// add here that you sent me in a reply
switch (cell.Column.Key)
{ } // show another form }
