Hi everyone,
I am new to Infragistics testing the basics of it. I would like to know how to populate an UltraDataSource dynamically please ? This UltraDataSource is going to be the source for my UltraTree afterwards. The UltraDataSource structure is determined at the beginning, but I would like to access its data structure outside the InitializeComponent() method so I can populate it dynamically with my out dataset. Any help would be greatly appreciated. Also, do you know where I can find some documentation about the UltraDataSource object's structure please ?
Thank you in advance
Victor
Hello Victor,
I am just checking about the progress of this issue. Let me know if you need my further assistance on it.
Hi Milko,First thanks a lot for looking at my request and apologies for my late reply I am very busy with various things but extremely interested to find a way to populate my UltraDataSource. Unfortunately I cannot feed it directly from a database (if that is what you meant?) because my data have to actually be computed before (maths calculations) and sorted out so I can actually build a proper dataSource (which object would you recommand by the way?) that would simply serve as a source for my UltraDataSource writting UltraDataSource.SourceData = myOwnComputedDataSet;My assumption is that taylor building this dataSet alone could be quite time and lines consuming which I think is not the idea of this component but if it allows to be fed this way then I could start looking at a way to build my own dataSet to feed my UltraDataSource (could you help on the structure of the UltraDataSource itself maybe?)I am actually in my trial period of Infragistics and got into it because Infragistics seemed to be the only company proposing this graphical component that I definitely need. Being simply able to do this would of course convince me to buy a licence. I know the graphical suite proposed can be very powerful but I am new to it and cannot find much documentation about it (could you show me where the documentation is please?). Also, I would rather use the forum to be sure I intend to use the components the way they have been thought and designed. I do not want to enter into terrible coding to achieve this since I assume this ultraDataSource must be a quite straigth forward component to feed.Again thanks for your time and your help.Kind regards,Victor
I am following up to ask whether or not if you have any additional questions with our UltraDataSource? If so, please let us know so we can assist you further.
Thank you for using Infragistics Controls.
Hi Milko,
I appreciate very much your efforts and fully detailed answers to help me. I will fully focus on this C# project from the 13th to the 30th of March so I need some time to come back to you. I will explore the best objects to have my data collected, computed and stored first, then I will look at your different proposals and come back to you with smarter and more precise questions. (please do not close the topic until then!)
Talk to you soon and again thanks for your help,
Best regards,
I will wait for your feedback after 13th of March.
Please do not hesitate to contact me during this time if you have any additional questions.
Hi Victor,
I am just checking about the progress of this issue. Did you solve your issue accordingly to the information that I provided you? Do you have any additional question?
Sincerely,
I am all good for now many thanks for your support.
Kind regards,
