I'm using a Infragistics XamDataGrid and I don't know how to enable filtering for a column having a CellValuePresenterStyle defined.
As shown in below code, i tried to filter by setting AllowRecordFiltering="True" but its not working. it works for other fields which dont have CellValuePresenterStyle.
<igDP:UnboundField Name="StatusCode" BindingPath="Description" Label="Status" Width="Auto" AllowEdit="True"> <igDP:Field.Settings> <igDP:FieldSettings AllowRecordFiltering="True" CellMinWidth="60"> <igDP:FieldSettings.CellValuePresenterStyle> <Style TargetType="igDP:CellValuePresenter"> <Setter Property="Template"> <Setter.Value> <ControlTemplate> --- control here </ControlTemplate> </Setter.Value> </Setter> </Style> </igDP:FieldSettings.CellValuePresenterStyle> </igDP:FieldSettings> </igDP:Field.Settings> </igDP:UnboundField>
Is there any way to do filtering on unbound field which having CellValuePresenterStyle?
Please suggest.
Hello Prashant,
Thank you for your post.
I have been looking into it. I created short sample application based on your scenario and I could not managed to reproduce the behavior that you have described. If you are not able to reproduce the issue with the attached sample application, would you please modify it with the functionality, that you are using, so it reproduces the issue. This way I would be able to further investigate this for you and provide you with more detailed information on this matter.
Thanks. It worked.
