We have a XamDatagrid in our Application and whenever we try to select all the entries in the Grid through mouse drag and drop action we get an error saying "Array out of bound exception" but when we select it manually through keyboard using shift , it works fine.
Can anyone help me out with this? Is this a know bug? Any resolutions?
I have been looking into your post.
I created a small sample application containing our XamDataGrid but I was not able to reproduce the behavior you are describing. I tested the scenario with our 15.1 Volume Release build (1000) and with the latest 15.1 Service Release build (2008) and the selection was successful. Could you, please, provide me with more information regarding what version of our assemblies you’re using? If possible, could you modify my sample application to reproduce the issue and send it back so I can investigate it further?
I'm just checking if you managed to resolve the issue you were having. If you require any further assistance, please do not hesitate to ask.
As we work on a application with sensitive information I can not share the screenshot of the error with you. But I have taken out the error log and if you can please help me resolve the issue using this if possible.
"at Infragistics.Windows.DataPresenter.DataPresenterBase.RecordSelectionEnumerator.GetNextSiblingRecord(Int32 levelIndex, Boolean& retry) at Infragistics.Windows.DataPresenter.DataPresenterBase.RecordSelectionEnumerator.GetNextSiblingRecord(Int32 levelIndex, Boolean& retry) at Infragistics.Windows.DataPresenter.DataPresenterBase.RecordSelectionEnumerator.MoveNext() at Infragistics.Windows.DataPresenter.DataPresenterBase.GetRecordsForSelection(Boolean select, RangeSelectionEvaluator evaluator) at Infragistics.Windows.DataPresenter.DataPresenterBase.CalculateSelectionRange(Record record, SelectedItemHolder newSelection, Boolean clearExistingSelection, Boolean select) at Infragistics.Windows.DataPresenter.DataPresenterBase.CalculateNewSelectionRange(ISelectableItem item, Boolean clearExistingSelection, Boolean select) at Infragistics.Windows.DataPresenter.DataPresenterBase.InternalSelectRange(ISelectableItem item, Boolean clearExistingSelection, Boolean select) at Infragistics.Windows.DataPresenter.DataPresenterBase.Infragistics.Windows.Selection.ISelectionHost.SelectRange(ISelectableItem item, Boolean clearExistingSelection) at Infragistics.Windows.Selection.SelectionStrategyExtended.OnMouseMove(ISelectableItem item, MouseEventArgs e) at Infragistics.Windows.Selection.SelectionController.OnMouseMove(MouseEventArgs e) at Infragistics.Windows.Controls.IGControlBase.OnMouseMove(MouseEventArgs e) at Infragistics.Windows.DataPresenter.DataPresenterBase.OnMouseMove(MouseEventArgs e) at System.Windows.RoutedEventArgs.InvokeHandler(Delegate handler, Object target) at System.Windows.EventRoute.InvokeHandlersImpl(Object source, RoutedEventArgs args, Boolean reRaised) at System.Windows.UIElement.RaiseEventImpl(DependencyObject sender, RoutedEventArgs args) at System.Windows.UIElement.RaiseTrustedEvent(RoutedEventArgs args) at System.Windows.Input.InputManager.ProcessStagingArea() at System.Windows.Input.InputProviderSite.ReportInput(InputReport inputReport) at System.Windows.Interop.HwndMouseInputProvider.ReportInput(IntPtr hwnd, InputMode mode, Int32 timestamp, RawMouseActions actions, Int32 x, Int32 y, Int32 wheel) at System.Windows.Interop.HwndMouseInputProvider.FilterMessage(IntPtr hwnd, WindowMessage msg, IntPtr wParam, IntPtr lParam, Boolean& handled) at System.Windows.Interop.HwndSource.InputFilterMessage(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled) at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled) at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o) at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs) at MS.Internal.Threading.ExceptionFilterHelper.TryCatchWhen(Object source, Delegate method, Object args, Int32 numArgs, Delegate catchHandler)
