Is there a way to turn off filter as you type on string columns? Basically I want my filter inputs to work exactly as numeric columns where a user would need to finish typing and hit enter to execute filtering.
Thanks.
Hello Sint,
Sincerely,
Thanks, I might submit the idea.
Using the Template Column worked for me. Here is a snippet for anybody interested ...
<ig:TemplateColumn Key="SomeKey" > <ig:TemplateColumn.HeaderTemplate> <DataTemplate> <TextBlock Text="Some Header"/> </DataTemplate> </ig:TemplateColumn.HeaderTemplate> <ig:TemplateColumn.FilterItemTemplate> <DataTemplate> <TextBlock Text="{Binding Value}"/> </DataTemplate> </ig:TemplateColumn.FilterItemTemplate> <ig:TemplateColumn.FilterEditorTemplate> <DataTemplate> <TextBox Text="{Binding Value, Mode=TwoWay}"/> <!-- NOTE: this allowed me to not send over every key stroke to the filter's view model. User has to tab out or hit enter for this to trigger update to source--> </DataTemplate> </ig:TemplateColumn.FilterEditorTemplate> </ig:TemplateColumn>
