Hi.
Can someone please Help?
We are using Infragistics.Win.UltraWinEditors.v3.2 and we would like to know if it is possible to have / simulate the same behaviour as the DateTimePicker has while selcting each part of the date / time?
Thank's in advance for the help.
You were not specific about which behavior you're referring to, so I'm not certain this will help you, but you can set the TabNavigation property to 'NextSection' to make the tab key stop at each section, and you can use the SpinButtonDisplayStyle property to make spin buttons appear.
If this is not what you are talking about, please repost with more details.
The behaviour we would like to have is the following:
This behaviour lets our user automatically select a specific part of the date just by navigating in the control using the arrow keys or by clicking on it and with this they can immediately change the corresponding value instead of having to select the part they wanto to change.
Than You
see attached
Thanks, That's the behaviour we are looking for.
But is it possible to obtain the same result with Infragistics.Win.UltraWinEditors.v3.2 ??
I've tried but to no avail because I didn't find the EDITOR Property.
Thanks for the help.
Thank's.
That's exactly what we were looking for. We were missing a reference.
