8920
igGrid editing configuration
I need to configure igGrid control so it can perform the following in the attached sample project ( igGrid001.html )
1. Out of all columns only last two should be editable ( 'inStock' and 'read')
2. 'inStock' should be a check box ( can make it checkable) and 'read' should be a drop down with two string values 'Yes' & 'No' and underlying boolean true/false ( now it is string)
3. on inStock values change it should fire event that will modify inStock value in data source ( obtain reference  to the data source object) and rebind grid to it again.
4. Same as 3 for 'read' change..
Thanks.
Grid001.rar
Parents Reply Children
No Data
