We want to apply our own custom filter that would have a simple query language string to be written in the filter combo box above any column. The language we have allows to enter "*searchstring" in the filter combo. We would use this string to create our own filter criteria and filtering in the "OnRecordFilterChanging" overriden method.
However, it seems the grid tried to validate the entered string immediately for a valid regular expression event before the "OnRecordFilterChanging" method is called or the "RecordFilterChanging" event is fired, and shows an error message box saying "Parameter name: Invalid expression pattern.". How to stop this?
regards,
EDIT: Corrected the error message
Hello Sid,
Thank you for your post!
I have been looking into your issue and it seems that you are using some custom implementation. Would it be possible for you to provide me with a small sample application that shows the functionality you are using?
This way I would be able to further investigate this matter for you.
I am just checking if you have any further questions on this matter. Please do not hesitate to let me know if you do.
