60
Insert Existing Tool in Ribbon Causes it to be removed from other Tabs
I have a ribbon with afew tools on.
Some of these span several tabs, and are one tool, this was all working fine until I changed the tools from ComboBox's to ControlContainers.
I needed to start using Control Containers with UltraDropDowns to include columns.
I have managed to add a Database Dropdown to every tab I have, however when I try and do the same with the ODBC ControlContainer I have created it removes it from another tab rather than keep it on the old tabs.
Is there some kind of setting within the control that I may have inadvertently changed?
Just seems that the 2nd control container wont stick and gets removed every time I try and add it somewhere else using the Add Existing.
Parents Reply Children
No Data
