2395
LoadCustomizations Does Not Restore Column Widths Properly
We have a problem where adding showing/hiding Fields in our grid causes the grid to not restore properly from saved data.
Below is our XAML. We inherit from XamDataGrid to add some functionality on top. Notice that all fields are * width, and several are collapsed by default (the user can show/hide columns at will).
<t:NTGrid    x:Name                            ="grdOrder"
            AutoFit                            ="False"
            CellContainerGenerationMode        ="Recycle"
            GroupByAreaLocation                ="None"
            GroupByAreaMode                    ="DefaultFieldLayoutOnly"
            InitializeRecord                ="OnInitializeRecord"
            IsResizeDeferred                ="True"
            Loaded                            ="OnGridLoaded"
            RecordContainerGenerationMode    ="Recycle"
            Tag                                ="OrderGrid"
            UpdateMode                        ="OnUpdate"
            AutomationProperties.AutomationId="OrderGridTable">
    <t:NTGrid.SuppressedEvents>
        <i:RoutedEventWrapper RoutedEvent="ie:ValueEditor.TextChanged" />
        <i:RoutedEventWrapper RoutedEvent="ie:ValueEditor.ValueChanged" />
        <i:RoutedEventWrapper RoutedEvent="i:DataPresenterBase.AssigningFieldLayoutToItem" />
        <i:RoutedEventWrapper RoutedEvent="i:DataPresenterBase.CellActivating" />
        <i:RoutedEventWrapper RoutedEvent="i:DataPresenterBase.CellActivated" />
        <i:RoutedEventWrapper RoutedEvent="i:DataPresenterBase.CellDeactivating" />
        <i:RoutedEventWrapper RoutedEvent="i:DataPresenterBase.DataValueChanged" />
        <i:RoutedEventWrapper RoutedEvent="i:DataPresenterBase.ExecutingCommand" />
        <i:RoutedEventWrapper RoutedEvent="i:DataPresenterBase.ExecutedCommand" />
        <i:RoutedEventWrapper RoutedEvent="i:DataPresenterBase.InitializeCellValuePresenter" />
        <i:RoutedEventWrapper RoutedEvent="i:DataPresenterBase.RecordActivating" />
        <i:RoutedEventWrapper RoutedEvent="i:DataPresenterBase.RecordActivated" />
        <i:RoutedEventWrapper RoutedEvent="i:DataPresenterBase.RecordDeactivating" />
    </t:NTGrid.SuppressedEvents>
    <t:NTGrid.FieldSettings>
        <i:FieldSettings    AllowEdit                    ="False"
                            CellClickAction                ="SelectRecord"
                            CellValuePresenterStyle        ="{StaticResource OrderGridCellValuePresenter}"
                            ForceCellVirtualization        ="True"
                            GroupByRecordPresenterStyle    ="{StaticResource OrdersGridGroupByRecordPresenter}"
                            LabelClickAction            ="SortByOneFieldOnly"
                            LabelTextAlignment            ="Center"
                            LabelTextWrapping            ="NoWrap" />
    </t:NTGrid.FieldSettings>
    <t:NTGrid.FieldLayoutSettings>
        <i:FieldLayoutSettings    AllowClipboardOperations    ="Copy"
                                AllowDelete                    ="False"
                                AllowFieldMoving            ="WithinLogicalRow"
                                AutoFitMode                    ="OnlyWithVisibleStarFields"
                                AutoGenerateFields            ="False"
                                CopyFieldLabelsToClipboard    ="True"
                                DataRecordPresenterStyle    ="{StaticResource SimpleDataRecordPresenter}"
                                DataRecordSizingMode        ="Fixed"
                                HeaderPlacementInGroupBy    ="OnTopOnly"
                                HeaderPrefixAreaDisplayMode    ="None"
                                LabelLocation                ="SeparateHeader"
                                MaxSelectedRecords            ="1"
                                RecordSelectorLocation        ="None"
                                SelectionTypeCell            ="None"
                                SelectionTypeRecord            ="Single" />
    </t:NTGrid.FieldLayoutSettings>
    <t:NTGrid.FieldLayouts>
        <i:FieldLayout Key="MainFieldLayout">
            <i:FieldLayout.Fields>
                <i:Field Name="Instrument"            Width="*" FixedLocation="FixedToNearEdge"/>
                <i:Field Name="StrategyId"            Width="*" FixedLocation="FixedToNearEdge" Visibility="Collapsed"/>
                <i:Field Name="OrderAction"            Width="*" />
                <i:Field Name="OrderType"            Width="*" />
                <i:Field Name="TotalQuantity"        Width="*" />
                <i:Field Name="LimitPrice"            Width="*"/>
                <i:Field Name="StopPrice"            Width="*"/>
                <i:Field Name="Price"                Visibility="Collapsed" Width="*"/>
                <i:Field Name="OrderStateString"    Width="*"/>
                <i:Field Name="Filled"                Width="*">
                <i:Field Name="AverageFillPrice"    Width="*" />
                <i:Field Name="Remaining"            Width="*" />
                <i:Field Name="OrderName"            Width="*" />
                <i:Field Name="StrategyString"        Width="*"/>
                <i:Field Name="OneCancelsOther"        Width="*" />
                <i:Field Name="TimeInForce"            Width="*" />
                <i:Field Name="Account"                Width="*"/>
                <i:Field Name="AccountName"            Visibility="Collapsed"    Width="*"/>
                <i:Field Name="OrderId"                Width="*" />
                <i:Field Name="Time"                Width="*"/ >
                <i:Field    Name="+"
                            BindingType="Unbound"
                            Label="{Resx ResxName=NinjaTrader.Gui.AccountData.OrderGrid, Key=GuiOrderGridIncrease}"
                            Width="*"
                            Visibility="Collapsed">
                    <i:Field.Settings>
                        <i:FieldSettings CellValuePresenterStyle="{StaticResource OrderGridIncreaseStyle}" />
                    </i:Field.Settings>
                </i:Field>
                <i:Field    Name="-"
                            Label="{Resx ResxName=NinjaTrader.Gui.AccountData.OrderGrid, Key=GuiOrderGridDecrease}"
                            Width="*"
                    <i:Field.Settings>
                        <i:FieldSettings CellValuePresenterStyle="{StaticResource OrderGridDecreaseStyle}" />
                    </i:Field.Settings>
                </i:Field>
                <i:Field    Name="X"
                            Label="{Resx ResxName=NinjaTrader.Gui.Resource, Key=GuiCancel}"
                            Width="*">
                    <i:Field.Settings>
                        <i:FieldSettings CellValuePresenterStyle="{StaticResource OrderGridCancelStyle}" />
                    </i:Field.Settings>
                </i:Field>
            </i:FieldLayout.Fields>
        </i:FieldLayout>
    </t:NTGrid.FieldLayouts>
</t:NTGrid>
Below is how the grid looks by default with no records:
Now say the user shows TWO of the columns that are collapsed by default, and resizes ONE of them (in this case, Increase was widened by the user):
Now, SaveCustomizations() is called when the program closes, and generates the following XML (Notice that the column named "-" has NO cell or label width in the XML):
<?xml version="1.0" encoding="utf-8"?>
<xamDataPresenter version="15.1.20151.2055" formatVersion="1.8">
  <fieldLayouts>
    <fieldLayout key="MainFieldLayout" orientation="Vertical" fieldList="Instrument, StrategyId;Int64, OrderAction, OrderType, TotalQuantity;Int32, LimitPrice, StopPrice, Price, OrderStateString, Filled;Int32, AverageFillPrice;Double, Remaining;Int32, OrderName, StrategyString, OneCancelsOther, TimeInForce, Account, AccountName, OrderId, Time;DateTime, +;Int32;unbound, -;Int32;unbound, X;Int32;unbound">
      <fields>
        <field name="Instrument" extendedInfo="Instrument" FixedLocation="FixedToNearEdge" cellWidth="32.933333333333323" labelWidth="32.933333333333323" Visibility="Visible" IgnoreFieldVisibilityOverrides="false" />
        <field name="StrategyId" extendedInfo="StrategyId;Int64" FixedLocation="FixedToNearEdge" Visibility="Collapsed" IgnoreFieldVisibilityOverrides="false" />
        <field name="OrderAction" extendedInfo="OrderAction" cellWidth="32.933333333333323" labelWidth="32.933333333333323" Visibility="Visible" IgnoreFieldVisibilityOverrides="false" />
        <field name="OrderType" extendedInfo="OrderType" cellWidth="32.933333333333323" labelWidth="32.933333333333323" Visibility="Visible" IgnoreFieldVisibilityOverrides="false" />
        <field name="TotalQuantity" extendedInfo="TotalQuantity;Int32" cellWidth="32.933333333333323" labelWidth="32.933333333333323" Visibility="Visible" IgnoreFieldVisibilityOverrides="false" />
        <field name="LimitPrice" extendedInfo="LimitPrice" cellWidth="32.933333333333323" labelWidth="32.933333333333323" Visibility="Visible" IgnoreFieldVisibilityOverrides="false" />
        <field name="StopPrice" extendedInfo="StopPrice" cellWidth="32.933333333333323" labelWidth="32.933333333333323" Visibility="Visible" IgnoreFieldVisibilityOverrides="false" />
        <field name="Price" extendedInfo="Price" Visibility="Collapsed" IgnoreFieldVisibilityOverrides="false" />
        <field name="OrderStateString" extendedInfo="OrderStateString" cellWidth="32.933333333333323" labelWidth="32.933333333333323" Visibility="Visible" IgnoreFieldVisibilityOverrides="false" />
        <field name="Filled" extendedInfo="Filled;Int32" cellWidth="32.933333333333323" labelWidth="32.933333333333323" Visibility="Visible" IgnoreFieldVisibilityOverrides="false" />
        <field name="AverageFillPrice" extendedInfo="AverageFillPrice;Double" cellWidth="32.933333333333323" labelWidth="32.933333333333323" Visibility="Visible" IgnoreFieldVisibilityOverrides="false" />
        <field name="Remaining" extendedInfo="Remaining;Int32" cellWidth="32.933333333333323" labelWidth="32.933333333333323" Visibility="Visible" IgnoreFieldVisibilityOverrides="false" />
        <field name="OrderName" extendedInfo="OrderName" cellWidth="32.933333333333323" labelWidth="32.933333333333323" Visibility="Visible" IgnoreFieldVisibilityOverrides="false" />
        <field name="StrategyString" extendedInfo="StrategyString" cellWidth="32.933333333333323" labelWidth="32.933333333333323" Visibility="Visible" IgnoreFieldVisibilityOverrides="false" />
        <field name="OneCancelsOther" extendedInfo="OneCancelsOther" cellWidth="32.933333333333323" labelWidth="32.933333333333323" Visibility="Visible" IgnoreFieldVisibilityOverrides="false" />
        <field name="TimeInForce" extendedInfo="TimeInForce" cellWidth="32.933333333333323" labelWidth="32.933333333333323" Visibility="Visible" IgnoreFieldVisibilityOverrides="false" />
        <field name="Account" extendedInfo="Account" cellWidth="32.933333333333323" labelWidth="32.933333333333323" Visibility="Visible" IgnoreFieldVisibilityOverrides="false" />
        <field name="AccountName" extendedInfo="AccountName" Visibility="Collapsed" IgnoreFieldVisibilityOverrides="false" />
        <field name="OrderId" extendedInfo="OrderId" cellWidth="32.933333333333323" labelWidth="32.933333333333323" Visibility="Visible" IgnoreFieldVisibilityOverrides="false" />
        <field name="Time" extendedInfo="Time;DateTime" cellWidth="32.933333333333323" labelWidth="32.933333333333323" Visibility="Visible" IgnoreFieldVisibilityOverrides="false" />
        <field name="+" extendedInfo="+;Int32;unbound" cellWidth="56.1" labelWidth="56.1" Visibility="Visible" IgnoreFieldVisibilityOverrides="false" />
        <field name="-" extendedInfo="-;Int32;unbound" Visibility="Visible" IgnoreFieldVisibilityOverrides="false" />
        <field name="X" extendedInfo="X;Int32;unbound" cellWidth="32.933333333333323" labelWidth="32.933333333333323" Visibility="Visible" IgnoreFieldVisibilityOverrides="false" />
      </fields>
    </fieldLayout>
  </fieldLayouts>
Now, when the user restarts and we call LoadCustomizations(), this is how the grid appears:
Why is this the case, or what can we do to fix this?
Parents
  • 2395
    I'm noticing that the screenshots appear cut off on the right side. Please Right-click on the images and View Image in order to see the entire image, thanks.
Reply Children
