I have Windows 10 and using v.2014.2.
When I try to run, I get the wait icon, then nothing.
in the windows app error log, I have two errors:
Infragistics4.Win.AppStylist.v14.2.exe 14.2.20142.2092 54ee8d7c KERNELBASE.dll 10.0.10586.0 5632da1c e0434352 000bd8a8 78c 01d162aace1a182b C:\Program Files (x86)\Infragistics\2014.2\Windows Forms\AppStylist for Windows Forms\Infragistics4.Win.AppStylist.v14.2.exe C:\Windows\SYSTEM32\KERNELBASE.dll f3c41662-6d38-4fc2-81e9-d32141408a02
and
Application: Infragistics4.Win.AppStylist.v14.2.exe Framework Version: v4.0.30319 Description: The process was terminated due to an unhandled exception. Exception Info: System.IO.FileNotFoundException at Infragistics.Win.AppStyling.Runtime.AppStylistDialog.Main(System.String[])
Any idea?
thanks
Hi Mark,
Thank you for posting in our forums!
Based on your kindly provided information, I am not able to reproduce this error on Windows 10 x64 bit machine with the latest service release of Infragistics 14.2 and therefore an additional information and probably a screenshot will be required.
What’s the build number of your operating system? Is it x86 or x64 bit? Is it up to date? What’s the service release version of Infragistics 14.2? Do you reproduce this issue on another development machine? What versions of Visual Studio and .NET framework are installed? If any, how many Infragistics service releases are installed on top of each other?
I actually got it working by uninstalling Infragistics and re-installing it.
It's weird because I tried that once and it didnt work. But then installed 2015.2 (which worked) then uninstalled 2014.2 and reinstalled it.
