Hello.
I’m using an UltraChart control, and I have faced a problem with touch screens.When I’m trying to resieze the Chart( Line graph ) whith touch, UltraChart control can't get ZoomGesture Event and other Gesture Event which Ultra picture can get.I want to make the UltraChart control to get any Gesture Event.
Is there a solution to this issue?
Best Regard
Kazuhiro Murai
Hi Kazuhiro,
Thank you for posting in our forums.
The UltraChart doesn’t support gesture events. You can use the UltraDataChart control if you want a chart control which has support for gestures. For more information about the control, please follow this link:
http://help.infragistics.com/Doc/WinForms/current/CLR4.0/?page=DataChart_DataChart.html
Please let me know if you have any additional questions.
Thank you for answers and quick replay.
I will use it as a reference!!
Thank you for answers.I tryed to use it as your reference URL.I found the follwing URL that the gesture operation is explained.http://help.infragistics.com/Doc/WinForms/current/CLR4.0/?page=DataChart_Navigating_Chart_Using_Touch_Gestures.htmlBut this explaination is not matched with my demand.
Certainly after I changed propaties of chart.HorizontalZoomable and chart.VerticalZoomable,the gesture is effecived to Zoom in and out, etc.
but I want to use tha gesture event as the UltraPicture Box has.・GestureCompleted・GestureQueryStatus・GestureStarting・PressAndHoldGesture・PressAndTapGesture・TwoFingerTapGesture・ZoomGesture
Thank you for the reply.
Yes it seems that the touch gesture events are not present in the UltraDataChart. I would suggest to add a new product idea for exposing the touch events in our product ideas site.
