60
Passing Angular scope members to axis and series members.
In the following HTML using the IgniteUI angular directives, if I try to pass a scope value to a series title ( title="scopeValue" ) it just give me the literal 'scopeValue' in the rendering on the web page for the series title. If I use the same scope variable mustached {{}} then I get nothing. The data-source works fine using a scope value.
I know I can work around this (and have) for other thing by just using jQuery in my angular controller, but we're trying to use Angular. Also, I would like to pass a scope variable which is set to a function() for formatting the series axis title or tool-tip-template.
Any one have any ideas, and thank in advance.
            data-source="delinquencyRatios60Plus"
         window-response="immediate"
         width="100%"
         height="500px">
             type="categoryX"
        label="Column">
             type="numericY"
        minimumvalue="0">
            type="column"
       is-highlighting-enabled="true"
       is-transition-in-enabled="true"
       x-axis="TypeAxis"
       y-axis="ValueAxis"
       title="scopeValue"
       show-tooltip="true"
       value-member-path="MeasureValue">
Parents Reply Children
