70
XamPivotGrid scrolling performance
I’m currently using XamPivotGrid with a FlatDataSource bound to an ObservableCollection containing about 1500 items. The source object class consists of 10 members. Three of them  are measures and three of them are dimensions. If I expand all hierarchies and start to scroll through the grid, I experience a bad scrolling performance.
                         | Year
M1,M2,M3           | 2007         | 2008        | ...  | 2016        |
                         | M1,M2,M3 | M1,M2,M3 | ...  | M1,M2,M3 |
  Type |   Name1  |
          | Name 99 |
After having analyzed my application with dotTracePerformance I found out that the ‘RenderCell’ method took a lot of time and caused the problem.
Is there any possibility to fix this problem?
Parents
No Data
Reply
  • 10
    I’m also facing similar scrollbar performance issue with XamPivotGrid. The XamPivotGrid uses FlatDataSource bound to an ObservableCollection of 300 items.The visible columns are only 7.When applying filter on 3 columns, the scrollbar performance becomes very bad. Can you please provide some suggestion to improve the scrollbar experience with multiple filter columns.
Children
No Data
