Hi there,
I've started to use this great control inside the xamDockManager however I've noticed that the chart loses its starting aspect ratio when moving the host window to dock at other locations. Is there any way to lock the aspect ratio of the chart such that the dockmanager window size is irrelevant?
Many Thanks
Simon
Hello Simon,
Can you please attach an isolated sample project that reproduces the behavior you've described? Thanks in advance.
Hi Michael,
Sorry this is not longer an issue as we've had a agile requirements U turn!
The issue was the axes on the chart are different lengths depending on the initial size of the hosting window. My question was merely if the axes could be constrained to be the same size (aspect).
Best Regards
