295
RunTime error ValueListDropDownUnsafe - winGrid
Our application is winforms userControl which is invoked within VB6 using a interop, this works perfectly fine.  However with that said, there is a senrio where the system throws a RT.
Step1: Open a form with wingrid that has data and open grid filter,
Step 2: Close the form, without collapsing the filter dropdown. Even though the form is closed some kind of object remains on the MDI
Step 3: Open another form and click on any kind of drop down. The system blows with the below exception.
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.ObjectDisposedException: Cannot access a disposed object.
Object name: 'ValueListDropDownUnsafe'.
   at System.Windows.Forms.Control.CreateHandle()
   at System.Windows.Forms.Control.get_Handle()
   at Infragistics.Win.DropDownManager.OwnsControl(Control control)
   at Infragistics.Win.DropDownManager.HandleClosingOfOpenDropDowns(Control owner)
   at Infragistics.Win.DropDownManager.DropDown(DropDownManagerParameters dropDownManagerParameters)
   at Infragistics.Win.ValueListDropDown.ShowHelper(Rectangle editRect, Int32 index, Boolean isDroppingDown)
   at Infragistics.Win.ValueListDropDown.DoDropDown(Rectangle editRect, Int32 index)
   at Infragistics.Win.ValueList.Infragistics.Win.IValueList.DropDown(Rectangle cellAreaInScreenCoords, Int32 index, String text)
   at Infragistics.Win.UltraWinGrid.ColumnHeader.OnClickFilterDropDown(HeaderUIElement headerElem, Boolean shiftKeyDown)
   at Infragistics.Win.UltraWinGrid.FilterDropDownButtonUIElement.OnMouseDown(MouseEventArgs e, Boolean adjustableArea, UIElement& captureMouseForElement)
   at Infragistics.Win.ControlUIElementBase.ProcessMouseDownHelper(Object sender, MouseEventArgs e)
   at Infragistics.Win.ControlUIElementBase.ProcessMouseDown(Object sender, MouseEventArgs e)
   at Infragistics.Win.Utilities.ProcessEvent(Control control, ProcessEvent eventToProcess, EventArgs e)
   at Infragistics.Win.UltraControlBase.OnMouseDown(MouseEventArgs e)
   at System.Windows.Forms.Control.WmMouseDown(Message& m, MouseButtons button, Int32 clicks)
   at System.Windows.Forms.Control.WndProc(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
    Assembly Version: 2.0.0.0
    Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000)
    CodeBase: file:///x:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
Cmc.UI.Winforms.CampusVue.Session
    Assembly Version: 11.0.0.71
    Win32 Version: 11.0.0.71
    CodeBase: file:///X:/Program%20Files/CMC/C2000/CAMPUSVUE/Cmc.UI.Winforms.CampusVue.Session.DLL
    CodeBase: file:///X:/Program%20Files/CMC/C2000/CAMPUSVUE/Cmc.UI.Winforms.CampusVue.DLL
Cmc.CampusLink.Client.Proxy
    CodeBase: file:///X:/Program%20Files/CMC/C2000/CAMPUSVUE/Cmc.CampusLink.Client.Proxy.DLL
Cmc.CampusLink.Client.BusinessEntities
    CodeBase: file:///X:/Program%20Files/CMC/C2000/CAMPUSVUE/Cmc.CampusLink.Client.BusinessEntities.DLL
Cmc.CampusLink.BusinessProcesses
    CodeBase: file:///X:/Program%20Files/CMC/C2000/CAMPUSVUE/Cmc.CampusLink.BusinessProcesses.DLL
System
    CodeBase: file:///X:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
Cmc.CampusLink.Soa
    CodeBase: file:///X:/Program%20Files/CMC/C2000/CAMPUSVUE/Cmc.CampusLink.Soa.DLL
Cmc.CampusLink.CodeAccessSecurity
    CodeBase: file:///X:/Program%20Files/CMC/C2000/CAMPUSVUE/Cmc.CampusLink.CodeAccessSecurity.DLL
Cmc.CampusVantage.Client
    CodeBase: file:///X:/Program%20Files/CMC/C2000/CAMPUSVUE/Cmc.CampusVantage.Client.DLL
System.Configuration
    CodeBase: file:///X:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
Cmc.UI.Winforms.CentralSecurity.Interfaces
    CodeBase: file:///X:/Program%20Files/CMC/C2000/CAMPUSVUE/Cmc.UI.Winforms.CentralSecurity.Interfaces.DLL
Cmc.UI.Winforms.CentralSecurity.Foundation
    CodeBase: file:///X:/Program%20Files/CMC/C2000/CAMPUSVUE/Cmc.UI.Winforms.CentralSecurity.Foundation.DLL
System.Web.Services
    CodeBase: file:///X:/WINDOWS/assembly/GAC_MSIL/System.Web.Services/2.0.0.0__b03f5f7f11d50a3a/System.Web.Services.dll
System.Xml
    CodeBase: file:///X:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
Cmc.CampusLink.BusinessEntities
    CodeBase: file:///X:/Program%20Files/CMC/C2000/CAMPUSVUE/Cmc.CampusLink.BusinessEntities.DLL
ksezpq49
System.Core
    Assembly Version: 3.5.0.0
    Win32 Version: 3.5.30729.1 built by: SP
    CodeBase: file:///X:/WINDOWS/assembly/GAC_MSIL/System.Core/3.5.0.0__b77a5c561934e089/System.Core.dll
t5pcwpjq
CMCClientLibrary
    Assembly Version: 1.0.1809.20554
    Win32 Version: 1.0.1809.20554
    CodeBase: file:///X:/Program%20Files/CMC/C2000/CAMPUSVUE/CMCClientLibrary.DLL
CMCBase
    Assembly Version: 0.0.1.20552
    Win32 Version: 0.0.1.20552
    CodeBase: file:///X:/Program%20Files/CMC/C2000/CAMPUSVUE/CMCBase.DLL
System.Data
    CodeBase: file:///X:/WINDOWS/assembly/GAC_32/System.Data/2.0.0.0__b77a5c561934e089/System.Data.dll
    CodeBase: file:///X:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
    CodeBase: file:///X:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
Accessibility
    CodeBase: file:///X:/WINDOWS/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
Cmc.UI.Winforms.CampusVue.Interfaces
    CodeBase: file:///X:/Program%20Files/CMC/C2000/CAMPUSVUE/Cmc.UI.Winforms.CampusVue.Interfaces.DLL
Cmc.UI.Winforms.CampusVue.Messages
    CodeBase: file:///X:/Program%20Files/CMC/C2000/CAMPUSVUE/Cmc.UI.Winforms.CampusVue.Messages.DLL
CmcFAControls
    CodeBase: file:///X:/Program%20Files/CMC/C2000/CAMPUSVUE/CmcFAControls.DLL
Csla
    Assembly Version: 3.0.0.0
    Win32 Version: 3.0.0.0
    CodeBase: file:///X:/Program%20Files/CMC/C2000/CAMPUSVUE/Csla.DLL
Infragistics2.Win.UltraWinChart.v8.2
    Assembly Version: 8.2.20082.1000
    Win32 Version: 8.2.20082.1000
    CodeBase: file:///X:/Program%20Files/CMC/C2000/CAMPUSVUE/Infragistics2.Win.UltraWinChart.v8.2.DLL
Infragistics2.Win.UltraWinGrid.v8.2
    CodeBase: file:///X:/Program%20Files/CMC/C2000/CAMPUSVUE/Infragistics2.Win.UltraWinGrid.v8.2.DLL
Infragistics2.Win.v8.2
    CodeBase: file:///X:/Program%20Files/CMC/C2000/CAMPUSVUE/Infragistics2.Win.v8.2.DLL
Infragistics2.Shared.v8.2
    CodeBase: file:///X:/Program%20Files/CMC/C2000/CAMPUSVUE/Infragistics2.Shared.v8.2.DLL
Infragistics2.Win.UltraWinGrid.ExcelExport.v8.2
    CodeBase: file:///X:/Program%20Files/CMC/C2000/CAMPUSVUE/Infragistics2.Win.UltraWinGrid.ExcelExport.v8.2.DLL
Infragistics2.Excel.v8.2
    CodeBase: file:///X:/Program%20Files/CMC/C2000/CAMPUSVUE/Infragistics2.Excel.v8.2.DLL
Cmc.DataAccess
    CodeBase: file:///X:/Program%20Files/CMC/C2000/CAMPUSVUE/Cmc.DataAccess.DLL
System.Web
    CodeBase: file:///X:/WINDOWS/assembly/GAC_32/System.Web/2.0.0.0__b03f5f7f11d50a3a/System.Web.dll
System.ServiceModel
    Win32 Version: 3.0.4506.2152 (SP.030729-0100)
    CodeBase: file:///X:/WINDOWS/assembly/GAC_MSIL/System.ServiceModel/3.0.0.0__b77a5c561934e089/System.ServiceModel.dll
System.Runtime.Serialization
    CodeBase: file:///X:/WINDOWS/assembly/GAC_MSIL/System.Runtime.Serialization/3.0.0.0__b77a5c561934e089/System.Runtime.Serialization.dll
SMDiagnostics
    CodeBase: file:///X:/WINDOWS/assembly/GAC_MSIL/SMDiagnostics/3.0.0.0__b77a5c561934e089/SMDiagnostics.dll
System.EnterpriseServices
    CodeBase: file:///X:/WINDOWS/assembly/GAC_32/System.EnterpriseServices/2.0.0.0__b03f5f7f11d50a3a/System.EnterpriseServices.dll
Infragistics2.Win.UltraWinPrintPreviewDialog.v8.2
    CodeBase: file:///X:/Program%20Files/CMC/C2000/CAMPUSVUE/Infragistics2.Win.UltraWinPrintPreviewDialog.v8.2.DLL
Infragistics2.Win.UltraWinDock.v8.2
    CodeBase: file:///X:/Program%20Files/CMC/C2000/CAMPUSVUE/Infragistics2.Win.UltraWinDock.v8.2.DLL
Infragistics2.Win.Misc.v8.2
    CodeBase: file:///X:/Program%20Files/CMC/C2000/CAMPUSVUE/Infragistics2.Win.Misc.v8.2.DLL
Infragistics2.Win.UltraWinEditors.v8.2
    CodeBase: file:///X:/Program%20Files/CMC/C2000/CAMPUSVUE/Infragistics2.Win.UltraWinEditors.v8.2.DLL
Infragistics2.Win.UltraWinToolbars.v8.2
    CodeBase: file:///X:/Program%20Files/CMC/C2000/CAMPUSVUE/Infragistics2.Win.UltraWinToolbars.v8.2.DLL
Infragistics2.Win.UltraWinStatusBar.v8.2
    CodeBase: file:///X:/Program%20Files/CMC/C2000/CAMPUSVUE/Infragistics2.Win.UltraWinStatusBar.v8.2.DLL
System.Design
    CodeBase: file:///X:/WINDOWS/assembly/GAC_MSIL/System.Design/2.0.0.0__b03f5f7f11d50a3a/System.Design.dll
Microsoft.VisualBasic
    Assembly Version: 8.0.0.0
    Win32 Version: 8.0.50727.3053 (netfxsp.050727-3000)
    CodeBase: file:///X:/WINDOWS/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
    <system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
ValueListDropDownUnsafe.rar
Parents
No Data
Reply
  • 1685
    This problem occured for us up to 12.1, but not in 13.1.
    In 13.1 the combo seems to get closed when it loses the focus better.
Children
No Data
