How to use 3d Pie chart in 16.1 version and how to give diffrent color dynamically to chart
Hello Vineet,
The XamPieChart in 16.1 does not currently support 3d visualizations and can only currently be viewed in 2d. This has been determined to be a new product idea, and as such, if you would like to see the ability for 3d visualizations added to the XamPieChart, I would recommend suggesting this new feature at http://ideas.infragstics.com.
Regarding setting different colors to the chart dynamically, I would recommend modifying the XamPieChart's Brushes property. This Brushes property accepts a new BrushCollection object, which you can then fill with the Brushes that you would like to use for the slices in your chart. The Brushes will be used in order, with the first data item in the XamPieChart's bound ItemsSource taking the first brush in the BrushCollection.
Sincerely,AndrewAssociate Developer
can you give best example for this issue
I have attached a sample project to demonstrate dynamically setting the Brushes property on the XamPieChart. In the sample project, on a button click, the Brushes of the XamPieChart are changed between a pair of BrushCollection objects after each click. Note again, that the Brush that exists at the 0 index of the BrushCollection will get assigned to the slice that represents the data item at the 0 index of your bound ItemsSource, as the indices of these two sources are proportional.
The sample project is attached to this post. I hope it helps you.
