In my project, there is an UltraGrid, from the Infragistics package (I know this isn't very commonly used, so not sure that asking here will get any answers), but, this UltraGrid is used to allow the input and amending of orders in an ordering system.When the order reaches 'Stage 4 - Awaiting Goods Delivery', the user can set the column value to True, which in turn prompts a new window, to allow the user to enter the volume and value of the delivery. If the order hasn't been fully delivered, the checkbox is set back to False, and the order line turns yellow (Eg; 5 gates have been ordered, but only 3 delivered = False, but a yellow order line).After saving the order, closing it and going back into it, I'm trying to set the Checkbox to True, to update the order to add on the rest of the delivery (the final 2 gates have been delivered), but as soon as I set it to True, it instantly becomes False again (When stepping through the following code in the CellChange method, it says the cell value is False too).So, why can I only change the value once? After it's been saved, why can the value then not be changed again? Is it do with the fact that it's saved as False in the database?
In case it helps, this is my code for the CellChange method
Try
If e.Cell.Column.ToString = "Goods_Delivered" Then
e.Cell.Row.Update()
If e.Cell.Value = True Then
If IsDBNull(e.Cell.Row.Cells("Final_Delivery").Value) Then
MsgBox("Please enter a delivery date", MsgBoxStyle.OkOnly, "Invalid Date")
e.Cell.Row.Cells("Goods_Delivered").Value = False
Else
Dim f As New dlgDelivery(e.Cell.Row, Me, e.Cell.Row.Cells("Final_Delivery").Value, con, orderNumber, e.Cell.Row.Cells("Product_Code").Value, exTotal)
f.ShowDialog()
End If
cmdCheck_Click(sender, New EventArgs)
cmdTotals_Click(sender, New EventArgs)
ElseIf e.Cell.Value = False Then
ugProducts.ActiveRow.Cells("Final_Delivery").Value = DBNull.Value
productCode = ugProducts.ActiveRow.Cells("Product_Code").Value
database.NotDelivered(orderNumber, productCode, con)
Exit Sub
Hi David,
There's nothing in the grid that would prevent the cell from changing twice. It must be something in your code that is doing that.
The code you have here is a bit strange and I think what might be happening is that you are causing recursion here.
Calling e.Cell.Row.Update() is not really a good idea. And there's certainly no reason to call it twice, as you are doing here. I suspect you are probably doing this because if you don't, the Value property will return the original value of the cell and not the new value.
What happens because the Value property of the cell reads from the data source, and the DataSource has not been updated at the time when CellChange fires. That's because for many cells, updating the Value of the data source every time the cell changes would cause problems. For example, if you have a DateTime cell and the user types into that cell, whatever they type would not be a valid value for the cell until they type in enough to make a complete date. So CellChange fires on every keystroke.
For CheckBox cells, of course, this is not a problem. But by forcing the entire row to be committed, you might inadvertently cause an exception because some other cell in the same row might have a pending change that isn't valid, yet.
I suspect that what might be happening here is that you are committing the value of the cell and then you are SETTING the value of the cell, which may be causing CellChange to fire again recursively, and after that I'm not sure what happens, but this probably isn't the best way to achieve what you want here.
A better way to handle this and get the current value of the cell as it appears to the user on-screen is to use the Text property of the cell instead of the Value.
Dim goodsDelivered As Boolean = Boolean.Parse(e.Cell.Text)
It looks like what you want to do is prevent the user from checking the Checkbox until the Delivery Date field is filled in. So rather than setting the value on the cell, which could cause recursion, you would be better off setting the Value on the cell's editor. And that way, there's no need to call Update on the Row.
Private Sub UltraGrid1_CellChange(sender As Object, e As CellEventArgs) Handles UltraGrid1.CellChange If e.Cell.Column.Key = "Goods_Delivered" Then Dim goodsDelivered As Boolean = Boolean.Parse(e.Cell.Text) If goodsDelivered = True Then If IsDBNull(e.Cell.Row.Cells("Final_Delivery").Value) Then Dim checkEditor As CheckEditor = e.Cell.EditorResolved checkEditor.Value = False End If End If End If End Sub
Thanks Mike, this fixed it. One more thing - I tried registering the license that I have for the Infragistics package that's installed on my work PC, but since I don't have the key from the CD I located it in regedit, but I was unable to register it as it said that the key was invalid?
I want to register it so that I don't have to have my support opportunities limited to 30 days, but I don't seem to be able to.
Any ideas what might be going wrong?
Try checking the About box. Find any Infragistics control, like the grid, on a form in the designer. Right-click the control and select "About" and the About box will show you your key.
Hi Mike,
Did this, I found the key, but it says it's already been registered, so I assume a colleague has done it, but nobody at the company is sure who or what the login for the account was... Any way I can get around this?
David,
You can transfer the key by emailing team@infragistics.com with the details for the key and what account you want it transferred to.
