630
Need help in Sorting and formating for the bound coloumn in pivot grid
I am facing the following issues in generating a Pivot grid.
1. Sorting is enabled and it works fine in few cases. It doesn't work for the column headers "Components,Clothing,Bikes.."
I have specified the following attributes, but still the sorting doesn't work on the mentioned columns.
   allowSorting: true,
   allowHeaderRowsSorting: true,
   allowHeaderColumnsSorting: true,
   firstSortDirection: "ascending",
   firstLevelSortDirection: "ascending",
2. How to do the number format for the specified columns "Components,Clothing,Bikes.."
I am not sure how to apply the formating for these columns.
I have attached the code for your reference
Parents
  • 23953
    If you want sorting feature for the igPivotGrid the custom aggregator is not the way to go. You should use the formatting function of the igGrid like this:
    $("#pivotGrid").on("iggridrowsrendering", function (evt, ui) {
    	// return if the column collection is not generated yet
    	if (ui.owner.options.columns && ui.owner.options.columns.length === 0) {
    		return;
    	for (var i = 0; i < ui.owner.options.columns.length; i++) {
    		if (ui.owner.dataSource.data()[0] && $.isNumeric(ui.owner.dataSource.data()[0][ui.owner.options.columns[i].key])) {
    			ui.owner.options.columns[i].formatter = function (val, rec) {
    				if(val > 1000)
    					return "<kbd style="background-color: green;">" + $.ig.formatter(parseFloat(val), "number", "numeric") + "</kbd>";
    				else
    					return "<kbd style="background-color: red; color: white;">" + $.ig.formatter(parseFloat(val), "number", "numeric") + "</kbd>";
    The code above binds to the igGrid.rowsRendering event and attaches a formatter function for all the columns that are  numeric. Inside the formatter function a styling and formatting is done for the cell value.
    Note: You should put this code before initializing the igPivotGrid.
    Best regards,
    Martin Pavlov
    Infragistics, Inc.
Reply Children
