API documentation says that there is not "getCellAddressString" method exposed by the topLeftCornerCell. You should instead pass a cell object to it as follows:
imageShape.topLeftCornerCell(sheet.getCell('C9'));
Please let me know if this solves the situation.
Thanks for the reply, but it does not solve the problem. It shows the below error
Cannot call method 'getHashCode' of null
Please help asap
You can track the status of the issue in the following case CAS*175080*K2G2H9
I have been facing the same issue, has this issue been fixed already?
No , the issue hasn't solved it yet. I dropped this process and took another way to attach an image in excel. I had created an html table and export it to an excel. In that way I can be able to attach an image. Hope that helps.
Thanks.
Do you have a sample of the workaround of the process you applied for your problem? And did you use the ig worksheet to add image to excel?
The issue is released and will be available in the service release trhat is scheduled to roll out on 24 March 2017. Please let me know if you have further questions.
Could you provide the code for add an image to the excel sheet
Here it is:
var image = new Image(); image.width = 400; image.height = 400; image.src = "banner.jpg"; var imageShape = new $.ig.excel.WorksheetImage(image); imageShape.topLeftCornerCell(sheet.getCell('C9')); imageShape.bottomRightCornerCell(sheet.getCell('D10')); worksheet.shapes().add(imageShape);
This code was suggested previously
Cannot call method 'getHashCode' of null.
You mentioned to have a workaround for it, in your new release do you have the code for it?
Phanindra.
I am also getting the same error. The code is below. Any Idea what I am missing here?
<!DOCTYPE html><html xmlns="http://www.w3.org/1999/xhtml"><head> <title></title>
<style> .right { float: right; }
#exportButton { float: left; } </style> <!--Required scripts--> <script src="http://code.jquery.com/jquery-1.11.3.min.js"></script> <!-- External files for exporting --> <script src="http://www.igniteui.com/js/external/FileSaver.js"></script> <script src="http://www.igniteui.com/js/external/Blob.js"></script>
<!-- Ignite UI Loader Script --> <script src="http://cdn-na.infragistics.com/igniteui/2016.2/latest/js/infragistics.loader.js"></script>
<script> $.ig.loader({ scriptPath: "http://cdn-na.infragistics.com/igniteui/2016.2/latest/js/", cssPath: "http://cdn-na.infragistics.com/igniteui/2016.2/latest/css/", resources: 'modules/infragistics.util.js,' + 'modules/infragistics.documents.core.js,' + 'modules/infragistics.excel.js' }); </script> <script>
function createFormattingWorkbook() {
var workbook = new $.ig.excel.Workbook($.ig.excel.WorkbookFormat.excel2007); var sheet = workbook.worksheets().add('Sheet1'); sheet.columns(0).setWidth(96, $.ig.excel.WorksheetColumnWidthUnit.pixel); sheet.columns(4).setWidth(80, $.ig.excel.WorksheetColumnWidthUnit.pixel); sheet.columns(6).setWidth(96, $.ig.excel.WorksheetColumnWidthUnit.pixel);
var image = new Image(); image.width = 400; image.height = 400; image.src = "https://cdn2.iconfinder.com/data/icons/social-18/512/Facebook-2-64.png"; var imageShape = new $.ig.excel.WorksheetImage(image); imageShape.topLeftCornerCell(sheet.getCell('C9')); imageShape.bottomRightCornerCell(sheet.getCell('D10')); sheet.shapes().add(imageShape);
// Add merged regions for regions A1:D2 and E1:G2 var mergedCellA1D2 = sheet.mergedCellsRegions().add(0, 0, 1, 3); var mergedCellE1G2 = sheet.mergedCellsRegions().add(0, 4, 1, 6);
// Add two large headers in merged cells above the data mergedCellA1D2.value('Acme, Inc.'); mergedCellA1D2.cellFormat().alignment($.ig.excel.HorizontalCellAlignment.center); mergedCellA1D2.cellFormat().fill($.ig.excel.CellFill.createSolidFill('#ED7D31')); mergedCellA1D2.cellFormat().font().colorInfo(new $.ig.excel.WorkbookColorInfo($.ig.excel.WorkbookThemeColorType.light1)); mergedCellA1D2.cellFormat().font().height(16 * 20);
mergedCellE1G2.value('Invoice #32039'); mergedCellE1G2.cellFormat().alignment($.ig.excel.HorizontalCellAlignment.center); mergedCellE1G2.cellFormat().fill($.ig.excel.CellFill.createSolidFill('#FFC000')); mergedCellE1G2.cellFormat().font().colorInfo(new $.ig.excel.WorkbookColorInfo($.ig.excel.WorkbookThemeColorType.light1)); mergedCellE1G2.cellFormat().font().height(16 * 20);
// Format some rows and columns that should have similar formatting so we don't have to set it on individual cells. sheet.rows(2).cellFormat().font().bold(true); sheet.columns(4).cellFormat().formatString('$#,##0.00_);[Red]($#,##0.00)'); sheet.columns(6).cellFormat().formatString('$#,##0.00_);[Red]($#,##0.00)');
// Add a light color fill to all cells in the A3:G17 region to visually separate it from the rest of the sheet. We can iterate // all cells in the regions by getting an enumerator for the region and enumerating each item. var light1Fill = $.ig.excel.CellFill.createSolidFill(new $.ig.excel.WorkbookColorInfo($.ig.excel.WorkbookThemeColorType.light1)); var cells = sheet.getRegion('A3:G17').getEnumerator(); while (cells.moveNext()) { cells.current().cellFormat().fill(light1Fill); }
// Populate the sheet with data sheet.getCell('A3').value('Date'); sheet.getCell('B3').value('Description'); sheet.getCell('D3').value('Qty'); sheet.getCell('E3').value('Cost/Unit'); sheet.getCell('G3').value('Total');
sheet.getCell('A4').value(new Date('12/22/2014')); sheet.getCell('B4').value('Garage Door'); sheet.getCell('D4').value(1); sheet.getCell('E4').value(1875); sheet.getCell('G4').applyFormula('=D4*E4');
sheet.getCell('A5').value(new Date('12/22/2014')); sheet.getCell('B5').value('Trim'); sheet.getCell('D5').value(3); sheet.getCell('E5').value(27.95); sheet.getCell('G5').applyFormula('=D5*E5');
sheet.getCell('A6').value(new Date('12/22/2014')); sheet.getCell('B6').value('Install/Labor'); sheet.getCell('D6').value(8); sheet.getCell('E6').value(85); sheet.getCell('G6').applyFormula('=D6*E6');
// Add a grand total which is bold and larger than the rest of the text to call attention to it. sheet.getCell('E17').value('GRAND TOTAL'); sheet.getCell('E17').cellFormat().font().height(14 * 20); sheet.getCell('E17').cellFormat().font().bold(true);
sheet.getCell('G17').applyFormula('=SUM(G4:G16)'); sheet.getCell('G17').cellFormat().font().height(14 * 20); sheet.getCell('G17').cellFormat().font().bold(true);
// Save the workbook saveWorkbook(workbook, "Formatting.xlsx"); }
function saveWorkbook(workbook, name) { workbook.save({ type: 'blob' }, function (data) { saveAs(data, name); }, function (error) { alert('Error exporting: : ' + error); }); }
</script>
</head><body> <button id="exportButton" onclick="createFormattingWorkbook()">Create File</button> <br /> <img alt="Result in Excel" src="http://www.igniteui.com/images/samples/client-side-excel-library/excel-formatting.png" /></body></html>
It turns out that the constructor for the Worksheet image only takes a data uri. You cannot provide an Image element.
