Hi ,
I am creating a column Image Button dynamical but when i click on image ItemCommand is not get Fired .
Below are the code
void GridUserControl_OnInitializeRow(RowEventArgs e){var objCustomItemTemplateEdit = new EditCustomItemTemplate();objCustomItemTemplateEdit.ID = "Edit_" + selectedSpecialty;e.Row.Items[3].Template = objCustomItemTemplateEdit;
var objCustomItemTemplateDelete = new DeleteCustomItemTemplate();objCustomItemTemplateDelete.ID = "Delete_" + selectedSpecialty;e.Row.Items[4].Template = objCustomItemTemplateDelete;}
public class EditCustomItemTemplate : ITemplate{public string ID { get; set; }public string CommandArg { get; set; }
public void InstantiateIn(Control container){ImageButton p = new ImageButton();p.ID = ID;p.EnableViewState = true;p.CommandArgument = CommandArg;p.CommandName = "Edit";p.ViewStateMode = ViewStateMode.Enabled;p.ImageUrl = "Edit.png";container.Controls.Add(p);}
public class DeleteCustomItemTemplate : ITemplate{public string ID { get; set; }public string CommandArg { get; set; }
public void InstantiateIn(Control container){ImageButton p = new ImageButton();p.ID = ID;p.EnableViewState = true;p.CommandArgument = CommandArg;p.CommandName = "Delete";p.ViewStateMode = ViewStateMode.Enabled;p.ImageUrl = "dele.png"p.OnClientClick = "return confirm('Are you sure you want to delete this record?');";container.Controls.Add(p);}}
The reason that the ItemCommand event is failing to fire is that templates of the grid are instantiated in the DataBind method of the grid. Normally if this method is not manually called it gets called during the OnPreRender event for the grid. However, when using this with the ItemCommand the DataBind event is fired after the ItemCommand event is supposed to fire. Since the templates haven't been instantiated in time the event can't find the templates and fails out silently.
The way to resolve this issue is to ensure that the templates exist. You can do this by adding the following code to your PageLoad event:
if (IsPostBack) {
WebDataGrid1.EnsureTemplates();}
I tried using EnsureTemplates() method but it is not working.
You can find code below mention link
http://www.infragistics.com/community/forums/p/109368/514634.aspx#514634
Santosh.
Attach file is corrupt can you please attach the new file
Try this google drive link:
https://drive.google.com/file/d/0B1pRPnoDJMTTSXo4ZkFsSTJTaEk/view?usp=sharing
Its working first time but again when i click on dynamic generated image button its not get fired .... :(
Santosh
This is strange, in the sample that I've sent you ItemCommand server event is fired again while constantly clicking the button.
Getting issue when there is paging.
Its working fine but when i click on any page number then entire page is reloaded and then i click on image button item command event is not get fired and when i retry again then its work.
Thanks,.
Hello Santosh,
I saw the issue on the sample that you provided, although I couldn't determine what is the cause of it, because the sample is very complex. So in order to debug the issue I've created a simplified sample based on your scenario, although the issue do not persist there. Could you try to reproduce the issue on the new sample attached to my reply.
The only thing that I've noticed is that page index changed server event was not fired, and this somehow could be related to the issue.
Hi Zdravko Kolev,
Thanks for the sample code .
The sample code which you had provided had fixed column like OrderID, ShippedDate, ShipName , ShipCity etch but in my case based on xml template column will be created and shown ti the user.
In our project we will have one Custom Code which generate column based on xml template and same is shown to the user base on BL functionality like Edit , Delete or any more.
You can above mention logic code below mention link
http://www.infragistics.com/community/forums/p/109368/514634.aspx#514634 (User Control)
http://www.infragistics.com/community/forums/p/109460/515090.aspx#515090 (Helper Logic)
