Hi, I need an editor (UltraTextEditor, or an implemetation of the base class: UltraWinEditorMaskedControlBase)
in which the user enters a value and the display is a Custom Password String
Example:
Value: 1234567ABCD ValueDisplay : XYZW567ABCD (in edit mode both (InEditMode) true and false) where CustomPasswordString:XYZW
im inheriting from a EditorWithText (UltraTextEditor) in which i override the following method:
protected override string GetElementText(EmbeddableUIElementBase element, bool ignorePasswordChar) { String elementText = base.GetElementText(element, false); object value = element.Owner.GetValue(element.OwnerContext); EmbeddableEditorBase editor = element.Editor;
if (editor != null && editor.IsInEditMode && editor.IsEnteringEditMode && editor.IsValid) value = editor.Value;
if (value != null && !editor.IsEnteringEditMode && soportsPassword) { String originalText = editor.DataValueToText(value, element.Owner, element.OwnerContext, true);
elementText = String.Empty;
for (int i = 0; i < (String.IsNullOrEmpty(originalText) ? 0 : originalText.Length); i++) { if (i < passwordText.Length) elementText += passwordText[i].ToString(); else elementText += originalText[i].ToString(); } }
return elementText; }
The problem is the Custom Password String must be displayed in the editor mode, but when the Custom Password String is displayed it gets assigned the value from the editor (Value = ValueDisplay)
Value: 1234567ABCD ValueDisplay : XYZW567ABCDNew Value: 9988001234567ABCD ValueDisplay : XYZW001234567ABCD (OK) ValueDisplay : XYZW00XYZW567ABCD (Error)
